05-13-2008, 10:12 PM | #1 |
Newbie Join Date: Apr 2008 Location: FLA
| Painting outside of lexan?
I want my next body to be flat desert tan or flat olive drab. Any tips on doing this for lexan? Its for my ax10 and I wanna do something different. Also wondering who makes flat paints for lexan?
05-13-2008, 10:21 PM | #2 |
Quarry Creeper Join Date: Oct 2006 Location: Japan
I usually just paint the outside with a regular PS paint and the use the Tamiya TS matte clear to knock the shine of it!
05-13-2008, 11:06 PM | #3 |
well after some research I think I might paint the inside and 800 grit wet sand the outside for the flat finish.
05-13-2008, 11:12 PM | #4 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
| I would not use sand paper--how about a brillo pad or something of that sorts? One thing you have to worry about lexan is when it scratch's it turns whiteish...
05-14-2008, 06:44 AM | #5 |
Pebble Pounder Join Date: Dec 2006 Location: Earth
if you do paint the outside, spray the inside with a bit of silverish paint so it looks like the metal being exposed when you scrape the paint off when you roll over or try to drive through a rock |
05-14-2008, 09:36 AM | #6 |
Quarry Creeper Join Date: Oct 2006 Location: Great White North!
Not only paint the inside silver.. When painting the outside use a black or rusty color lexan paint firts then after that dries use a regular spray bomb in the flat color you want.. I like using the Krylon paint as it pretty durable.. But make sure you do your first couple coats in lexan paint otherwise the krylon doesnt bond that well on lexan!
05-14-2008, 05:25 PM | #7 |
Pebble Pounder Join Date: Jan 2007 Location: WEYMOUTH
use some steel wool and wipe it down with some mineral spirits, then use some adhesion promotor, then spray your color, i did this on my last truck with auto paint from atuozone looks great.
05-14-2008, 05:29 PM | #8 |
Paint the outside. Also paint the inside whatever color you want to show through... Rust worked for me |
05-14-2008, 10:40 PM | #9 |
Newbie Join Date: Apr 2008 Location: vancouver
| the more it is scratched, the better it looks |
05-19-2008, 08:22 PM | #10 |
Pebble Pounder Join Date: Jan 2005 Location: Blanchard
that scratch/rust looks awesome! It'll definitely be a part of the next body I do.
