Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: paint chipping
Old 01-04-2009, 12:32 AM   #1
Default paint chipping
so i have painted 2 bodies now that have chipped and the paint has cracked like hell. idk what im doing wrong. i have used lexan body paint. i did small coats. i cleaned the body before i painted them with water and soap and dried them out with a paper towel. i have done everything i can think of right. i was just wondering if anyone had any ideas to why its doing that. thanks
webster420 is offline   Reply With Quote
Old 01-04-2009, 12:37 AM   #2
From what you have written it sounds like the paint my be too thick. I find doing fine layers maybe about 3 coats max works for me!
When I started out I found this a good guide to help get started on the right foot ;)
http://www.rctech.net/articles/paint...ntedmyst.shtml
genki is offline   Reply With Quote
Old 01-04-2009, 12:45 AM   #3
ya i was wondering if maybe that was the case. i did one body with a airbrush and one with a rattle can. but i think your right it probably was kinda thick.
Old 01-04-2009, 01:03 PM   #4
Scrub the inside of the body with a scotchbrite pad while washing it with dish soap.
And don't use too much paint.
Manning is offline   Reply With Quote
Old 01-04-2009, 02:33 PM   #5
Location: Taylors Falls just hanging with the MNRCRC crew.
If your using fluorescent paint and it is applied to thick or its not backed buy a non fluorescent color usually white it can chip. :-(
Stormin2u is offline   Reply With Quote
Old 01-04-2009, 09:20 PM   #6
ok i will try all of those ideas. i think maybe i did use a little bit to much paint. i used fluorescent orange and blue and backed them with white. but i will try another one with not as much paint and less coats and see what happens
Old 01-05-2009, 01:34 PM   #7
This is a good tip and its what I also do, but do not wash the windows.
I use the rough part of a new dish washing sponge and light strokes.
You just want to rough up the surface a bit to get good adheartion.
ktmkurt is offline   Reply With Quote
Old 01-05-2009, 02:02 PM   #8
ok i will try that. i guess i have to get another body and try it again haha.
Old 01-06-2009, 12:04 AM   #9
What if after 3 coats the paint is still transparent? Is that what the white backing is for? Also how long should you wait in between coats. I have noticed with watching on youtube alot of people airbrush a body without even stopping to let layers dry.
Jmterminator is offline   Reply With Quote
Old 01-07-2009, 11:16 AM   #10
Team T1E/VP Driver
Uroplatus's Avatar
yeah... the Flourecent paints are transparent and need the white or silver backing to make it opaque. I typically do a 2 to 3 good even coats of the flourecent and then back with White... this will make the color POP out at cha too!!!
Uroplatus is offline   Reply With Quote
Old 01-07-2009, 11:38 AM   #11
ya me and jmterminator backed it with white and everything. it looked really good. i guess we will just have to try another one haha.
