08-14-2009, 12:03 AM | #1 |
Newbie Join Date: Jun 2009 Location: United States of Socialism Unfortunately
| Lexan paint choices are slim - no OD or yes?
So I've searched and have looked everywhere and can't find any OD (olive drab) or Desert Tan lexan paint in spray cans? Is this correct? I'm really hoping not. Tamiya or Pactra - whoever does these lexan paints really need to update their paint colors. They have been the same since the early 90's??? :-( |
08-14-2009, 12:59 PM | #2 |
Pixel Pusher Join Date: Feb 2005 Location: Kansas City
If you key (lightly scuff) the body on the outside, any lacquer based paint will adhere pretty well to the body. Just hit your local hardware store TIP: Apply the window masks to the outside of the windows prior to scuffing with a fine scotchbrite pad. Paint, then remove. Another TIP: Paint the inside of the body (reuse the masks) with rust brown or black or silver. When the paint gets scratched it will look realistic. |
08-14-2009, 01:23 PM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
im purdy darn sure that those colors are available in Krylon fusion flat colors, and the camo flat colors as well. i use the black on the outside of the body. you simply need to scuff up the surface that you will be painting. i had used fine grit sand paper with great success, i tried a green brillo pad and it didnt do the trick |
08-14-2009, 05:29 PM | #4 |
Rock Crawler Join Date: Feb 2008 Location: UK
Scotchbrite pad works really well for scuffing/keying Lexan.
08-14-2009, 05:55 PM | #5 |
THANK YOU FOR THE INFO!!! That's awesome. Soo I can just do normal black on the interior, and then (sanding sounds more promising) paint the outside after sanding with Fusion? Or just any Krylon will work on the outside? I think I have rustoleum in black/od - does that work on the outsaide? Or just stick to Fusion? Also - does anyone have any pics of this? I didn't find anything when I searched. Thanks! |
