02-08-2010, 01:07 PM | #1 |
Rock Crawler Join Date: Jun 2009 Location: SF
| Any paint geeks out there?? Rustoleum
So i've given up airbrushing comp bodies as I try and I try I just don't have the skill and paitence to make them real nice, plus I ruin them pretty quickly. Since RC paint for lexan is pretty expensive, does anyone know what the base for Rust-oleum spray paint for plastics is, or more to the point will my one color wonder (mabey 2) done in rustoleum plastic specialty paint hold up like stuff made for lexan?? The color choicer aren't great but I'm okay with black and white. The can says clean up with mineral spirits or xythol-I don't know if this helps. Thanks!
02-08-2010, 03:38 PM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Hudson County
Maybe Krylon Fusion for plastic. Make sure you spray in layers or it will drip. |
02-08-2010, 03:49 PM | #3 |
Quarry Creeper Join Date: Aug 2008 Location: Columbia, SC
Pactra in the spray can?
02-08-2010, 06:25 PM | #4 |
Pebble Pounder Join Date: Dec 2009 Location: Who Dat Louisiana
02-08-2010, 06:25 PM | #5 |
Newbie Join Date: Jan 2010 Location: Seattle
krylon fusion is a very good paint for plastics,durable plus it fuses with the plastic,so its kind of rough to remove,my first car (rc) i used the stuff,worked great
02-08-2010, 07:18 PM | #6 |
Quarry Creeper Join Date: Aug 2008 Location: Northern, Mi
I Paint alot of bodies for myself and friends. I come from a family that has 2 body shops and 1 custom painter. We have a lot of extra paint, mostly Dupont products and House of Kolor. I experimented with all kinds of paints and i keep coming back to the automotive grade paints. I sandblast the inside with a spot blaster, wash it, then spray it with a airbrush. I never had a problem using those paints as long as the body is either scuffed up or sand blasted. I leave it kinda thin so its a little transparent if held up in the light, That way it will not crack or flake off. |
02-08-2010, 08:12 PM | #7 |
Quarry Creeper Join Date: Jan 2010 Location: Gill, Taxachusetts
| I just did my B-17 Body with the Krylon for plastic and my kid dumped from the top of the stairs and it's still in good shape. Nothing flaked off.
02-08-2010, 09:48 PM | #8 |
Hmm, I used that fusion paint on my first on road car body. It looked good, but it flaked off after one good hit. I ended up hitting the body till all of it came off, then repainted. That was like 8 years ago or so, so maybe they changed the formula? But the best paint tp use that is cheap is Duplicolor auto paint. Think it says truck and van on the can. Auto part stores carry a full size can for 5 to 6 dollars. It last very long, even outlast the front bumper on an onroad car, since the lexan will crack from all the rocks b4 the paint will chip |
02-09-2010, 05:36 AM | #9 |
One thing to remember, The thicker the paint the less flexible it is. Meaning if you bend the body if will fall of in big chunks. Most rattle cans spray very thick. Paints also do not like to stick to any thing smooth or shiny. Your best bet would be to use scotch bright or some fine sand paper run over it at least once to give the paint something to hold on to. Always wash the body before you paint it. If there are any oils, chemicals or even dust from you or the body itself the paint will fall off. |
02-09-2010, 08:54 AM | #10 |
Don't take this the wrong way, but why would you bother with Krylon or other paint when a spray can of Pactra is the same price, and is made for lexan bodies. The stuff works and will not flake off.
02-10-2010, 01:52 AM | #11 | |
So no one uses the rustoleum for plastics? I'll report back in a few days with my 1 color wonder | |
02-10-2010, 07:18 AM | #12 |
Newbie Join Date: Oct 2009 Location: cent. IN
| question
ok should I use a scotch-brite or fine grit sandpaper on the inside of my body even if I am going to paint it using the Pactra paint?
02-10-2010, 08:06 AM | #13 |
If you like the Duplicolor auto colors you precoat with a adhesion promoter like Klean-Strips "Bulldog" they will not chip off. Bulldog is a clear material but mask the windows first.
02-10-2010, 10:08 AM | #14 | |
Scotch-brite is easier, It conforms to the lines of the body better. If all you have is sand paper it works to. | |
