Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: How to roll down windows lexan?
Old 07-06-2010, 02:58 AM   #1
Default How to roll down windows lexan?
Any tricks for getting the rolled down window look? (Lexan body)
volumeone is offline   Reply With Quote
Old 07-06-2010, 03:45 AM   #2
I joined the Band!
cut out the window to the spot you want it
crawlinnTN is offline   Reply With Quote
Old 07-06-2010, 06:01 AM   #3
mustangboy_347's Avatar
i usually use the left over window mask that i pull off and stick it to the outside of the window and trace it with a newer sharpie and use a new #11 blade to trim around the edge of the window and the mask and they come out great ....put the masking where ever you want the window down to ...hope this helps
mustangboy_347 is offline   Reply With Quote
Old 07-06-2010, 04:39 PM   #4
anyone got pictures of this it sounds like a cool effect and I wouldn't mind trying it.
HingedMosquito is offline   Reply With Quote
Old 07-07-2010, 05:41 PM   #5
really
Old 07-07-2010, 05:54 PM   #6
Thank you mb! sweet breakdown blade choice and all
Old 07-08-2010, 05:36 PM   #7
Do a search for threads by member jwalker....can't remember the thread title, but he did that to my drifter body. It looks really good, hopefully he'll chime in with the title cause it's slipping my mind...
EDIT: NoobCrawler's digi camo drift body
There you go, thread title
NoobCrawler is offline   Reply With Quote
Old 07-10-2010, 10:33 AM   #8
You could also mask off the area you want to look open and then tint the remaining window, the clear area looks open.Works fine until you scratch the clear area.
Dennis P is offline   Reply With Quote
Old 07-10-2010, 12:44 PM   #9
kinda crappy picture but hope you can see it
Old 07-10-2010, 03:42 PM   #10
Here's a pic of my old TLT crawler...
I used an Xacto knife and a dremel and sanded the edges.
WolverineX is offline   Reply With Quote
