05-23-2011, 09:03 AM | #1 |
Newbie Join Date: Feb 2011 Location: hong kong
| can anyone help me??
Can you guys teach me how to mount a hilux body on a scx-10 trail honco?? Pls reply. thx a lot |
05-23-2011, 12:38 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Check out the scale sections and do some searching and you will find many different solutions. I think there is even a thread or two in this section on it.
05-23-2011, 05:06 PM | #3 |
Newbie Join Date: Feb 2008 Location: wi
| scale body mounting
dont drill holes in it, use either velcro or magnets to hold your scale shell on so it looks scale. Unless you can disguise your front mounts as bonnet/hood pins
05-24-2011, 06:58 AM | #4 |
Rock Stacker Join Date: Sep 2010 Location: western mass
no one helps on here they just say search
05-24-2011, 07:28 AM | #5 |
05-24-2011, 08:30 AM | #6 |
teach a man to fish |
05-24-2011, 08:36 AM | #7 |
| Some of you just love to whine. I wasn't rude about it, just offered help. There is plenty of info out there on this subject already and I pointed him in the right direction. I guess your one of those people that need to be spoon fed everything though. |
05-24-2011, 04:05 PM | #8 |
Rock Stacker Join Date: Sep 2009 Location: Virginia
Here is how I did mine.. 1 inch wide Aluminum strip from local hardware store a couple nuts and bolts and some velcro.. Very simple process, I also made a battery mount in the front too... |
05-28-2011, 08:45 PM | #9 |
would that be strong enough to hold the body??
05-29-2011, 05:05 AM | #10 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
| There are different kinds of "Velcro" you can buy. I bought some industrial strength stuff. Comes in a box with very long strips of both sides (hook,loop). It should last forever. The industrial strength is very good for holding bodies on. The regular is ok and will work. But the Industrial stays stuck to what you aply it to much better and sticks to the other half of the velcro much stronger. I have done a few bodies in the manner that Wes81 showed and it works great. General google search came up with this. It is the same type i used but when I bought it the packaging was slightly different. 4 feet of each side http://www.concordsupplies.com/velcr...593/85323.html |
05-29-2011, 08:45 PM | #11 |
It holds very good.. The body has never got knocked off mounted like this, the only thing so far is if it takes a hard enough hit it might move the body a little.. You just have to be careful taking the body off because this stuff is strong...
05-29-2011, 09:45 PM | #12 |
Rock Stacker Join Date: May 2011 Location: Lake Stevens
I mounted mine on my sliders. I dont know if that helps or not.
