07-07-2011, 01:21 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: Agoura Hills, CA
| Pearl white???
Just made my first attempt at a rattle can (pactra) pearl white finish. The guy at the hobby shop told me to back a few coats of pearl white with silver. Guess what...my shell is now silver. The pearl white paint was barely visible when I sprayed it on, a slight milky look. Was the can defective or is silver the wrong backing paint to use? Thanks for any help. Last edited by JEB21; 07-07-2011 at 01:22 PM. Reason: grammar |
07-07-2011, 05:03 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
You should have backed it with regular white then maybe a silver if you wanted. Sounds like your guy at the hobby shop has no idea what he is talking about.
07-07-2011, 05:11 PM | #3 |
07-08-2011, 05:39 AM | #4 |
Newbie Join Date: Jun 2011 Location: Newfoundland, Canada
Sounds to me like the guy at the rc shop didn't know what he was talking about, I would say the silver was two dark to show the pearl. I have a pearl white body that I painted and the pearl coat went on just like you had described it, I pretty sure I only had two coats at the most and it gave it a thin milky layer that was still mostly transparent then I backed it with a few coats of white and it turned out perfect. Sounds like the guy at the rc shop should have told you to use white, not silver. |
07-08-2011, 05:49 AM | #5 |
Did you use translucent pearl? Meaning was the top of the can somewhat clear? If so you have to use several coats (sometimes 2 cans depending on body size) of it then back it with a few coats of metallic white if available until you hold the shell up to the light and can see an even paint job. If not even do a slow respray again. Then back the entire deal with silver. If you want a darker pearl you can go with black. |
07-08-2011, 11:27 AM | #6 | |
07-08-2011, 12:26 PM | #7 |
Pearl white is not a solid color, it must be backed with something else. Really it should be called "white pearl". All candy and pearl colors are translucent. If you use 2 cans of paint on one body you're doing it wrong. Way wrong. |
07-08-2011, 05:53 PM | #8 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| 3-4 coats of translucent pearl white, and and backed with florescent white.
07-08-2011, 07:04 PM | #9 |
07-09-2011, 12:08 AM | #10 |
Oh really? Sometimes I end up using 2 cans of paint on my short course bodies...especially if I'm doing 3 or more colors. Darkest colors first of course. For some reason Pactra's metallic blue just isn't that dark. I ended up having to use two cans just for 3 coats to get smooth coverage before backing it with white which was my second color along the fenders. Then backed all the colors with a coat of silver. Is that too much paint? |
07-09-2011, 06:55 AM | #11 |
07-09-2011, 11:47 AM | #12 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
07-09-2011, 06:53 PM | #13 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
I've never actually used a rattle can to paint a lid but being a kustom painter by trade...Im VERY familiar with the techniques & results in pearls, candies, metallics etc. They're absolutely correct. Any actual pearled paint is either a clear or translucent carrier with a pearlized "pigment". While you CAN lay down enough coats to get a full, opaque coverage...that's not the best way. Granted...my work vs. an RC lid is different in the fact that I would lay down my base then a pearl coat...the concept is the same. Light Pearl coats...1-3 unless ya want it "extra pearly" then backed by the color you're after for the main body. If you want a white lid with a purple pearl...then obviously you'd back it with white. If you want a blue lid with blue pearl...backed with blue & so on. I'd personally stay away from backing any pearl coats with a metallic simply because you're gonna lose the effect in the base coat. A true pearl coat casts a different color when shifted in the light. Looks white head on & blue from another angle.
07-27-2011, 07:44 AM | #14 |
Wow I guess I am using WAAAY too much paint! On my SC10 body I ended up using like 3 cans and 1 can for the backing. Obviously if I use too much it will flake off on impacts. What is a good rule of thumb for any lexan body painting using rattle cans? On my crawler lexan bodies I just use 1 can + 1 coat of backing. |
07-27-2011, 05:45 PM | #15 | |
I'll typically do three light coats for coverage, then a one coat backer. Even on a sc body you shouldn't use that much paint. One can should be plenty for 2-3 bodies. When doing a pearl color you'll use as many light coats as you think you need for the desired effect, then a light coat or two of color, then a backer. | |
07-27-2011, 05:53 PM | #16 |
Here's a pic of my old Slash. One light pearl coat under the black, then two light coats of black, two orange, and two silver. [IMG][/IMG] I'll see if I can dig up on of my old TMaxx...brighter colors but still the same amount of paint used. |
