Need Tamiya Toyota Hilux Bed Measurements? Ok so I am building a 1.9 scale hilux on a TCS L trial frame with losi mrc parts. I have it mocked up but dont have the bed. I was wondering if anyone had some measurements on the rear bed? This is my truck. Idk if a bed is going to fit or I am going to need to lengthen the frame. So could anyone give me some specs on the bed? I need to know how long it is from front to back. And then the length between the front of the bed to the start of the front wheel well. Then the same but for the rear. http://i1096.photobucket.com/albums/...8-26152852.jpg Thanks! |
wb is about 11.4" if that helps. Looking at your pic the l trail is gonna be short. X trail would probably be a better bet. |
Looks like plenty of frame there but you mite have to lengthen the wheel base in order for your back tires to line up with the wheel well's in the bed. Unless you bob the bed and remove some length from the front of the bed insted of the rear like most do it. From your pic it looks like the distance from the back of the cab to the front of the rear tire is really short. |
