09-24-2011, 09:33 PM | #1 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
| High $$$ paint job look on a budget
If you ever want that deep metallic candy multi stage paint job on a hard body but can't afford the automotive paints or have someone do the work? well here is a way to do it yourself on the cheep. Now for this paint job i wanted a dark red metallic so here are the paints i used: From left to right, Rust-oleum primer, gloss black, Metallic silver, Krylon X Metals in red, and clear glaze. I began by cleaning the newely formed panel then i primered it with one good coat. (note: when doing this on a hard body you will need to use a plastic safe primer) Next is the black, 2 coats. I used black to darken the red but you could use silver, white or even another color for different effects. Now here is the trick to get that metal flake look, I added the sliver very lightly only misting it on. Another thing to note, once you get to this point let the paint set for at least a couple days. a week in best. this gives it time to cure. if it's not fully cured the Krylon will react to it and may cause wrinkles. Once cured i added 2 coats of the Krylon X Metals. this is basically a candy so the more coats you put on the darker it will appear. Yes it will look hazy but the clear will take care of that. And here it is cleared and buffed. and a shot of the metallic here it is beside the panel i was replacing and now in place. I hope this helps some people out and encourages others to try painting themselves. you can play with base colors and the X Metals come in blue and purple the there are many different paint jobs to be made. |
09-24-2011, 09:53 PM | #2 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Wow I love that.... |
09-24-2011, 10:34 PM | #3 |
RCC Addict Join Date: May 2011 Location: Utah County
nice! i guess i need to go buy some gloss enamel to finish mine off. i wondered why it was so flat.
09-26-2011, 12:50 AM | #4 |
RCC Addict Join Date: Nov 2008 Location: Frederick
That's purdy damn cool. I'd F up the misting part every time. Each pice would be diff. |
09-29-2011, 08:20 AM | #5 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
Very kool stuff, thanks for the writeup! Matt |
09-29-2011, 08:32 AM | #6 |
Rock Crawler Join Date: Oct 2007 Location: south of France
nice job the truck look cool too, any build tread ?? |
09-29-2011, 09:12 AM | #7 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
09-29-2011, 11:17 AM | #8 |
Pebble Pounder Join Date: Apr 2011 Location: Cerritos
that came out amazing, thanks for the tip!
09-29-2011, 12:01 PM | #9 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| hope metal masher doesnt mind me posting his stuff here is his build thread on this truck. the panels are hand formed metal(little thicker than aluminum foil) over hand made molds. old comp truck turned scale truck (the rebuild!) ^build thread Project true scale - Aluminum Toyota body! ^here is another ridiculously nice build that he's done/is working on. Aluminum panel forming how-to ^here's a couple vids of how he makes his panels. metal masher- thats awesome!! i can get the fancy expensive PPG paint for free or very cheap but its not worth it on a crawler so its nice to know that i can achieve the same result on a budget!! again i hope you dont mind me posting up some build threads, if so, then let me know i will cut them out |
09-29-2011, 07:57 PM | #10 | |
09-29-2011, 09:42 PM | #11 |
09-29-2011, 09:48 PM | #12 |
RCC Paint & Graphics Join Date: Oct 2005 Location: Wauseon, OH.
Very, very nice! Thanks for sharing. |
09-30-2011, 04:57 AM | #13 | |
thanks a lot man !!! but that kill my day !! Metalmasher you got a real talent! so amazing work !!!! | |
09-30-2011, 10:23 AM | #14 |
