11-12-2011, 03:58 AM | #1 |
RCC Addict Join Date: Oct 2008 Location: Finland
| What finish is used on most Delrin chassis'?
I'm wondering how the matt finish is achieved found on most black delrin chassis' on the market today. Delrin sheet has a shiny finish when you buy it. Are the manufacturers sand blasting their Delrin chassis' or what do they do?
11-12-2011, 04:19 AM | #2 |
I think I found the answer to my question. It must be a result of some sort of deburring tumbler, am I right? Homemade Tumblers - Cast Boolits |
11-12-2011, 06:24 AM | #3 |
Lightly rubbing a piece of delrin with a scotchbrite pad will give you a nice flat finish. You can buy "fine" or "coarse" scotchbrite pads that will give a slightly different texture. Nice thing about scotchbrite is one or two passes over a part removes all the sharp edges, removes any light blemishes and leaves a nice uniform finish.
11-12-2011, 06:33 AM | #4 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
CDW uses an orbital sander with a 220 grit pad, then it gets wiped down with WD-40. makes for a very nice uniform matte finish.
11-12-2011, 06:58 AM | #5 |
Like any plastic, when you sand it, the "dust" can stay on the surface. Washing the parts with warm soapy water or wiping them off with a lightly oiled rag is a must IMO.
11-12-2011, 08:00 AM | #6 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
been sanding mine with a random orbit sander as well, really like the finish, and with some of the 1/4" if been getting from mcmaster lately, its a must on the skids at least.
11-12-2011, 10:44 AM | #7 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
Media blast makes a nice unique finish. Both pieces of delrin are the same the one on the bottom has just been blasted. Last edited by highlandcrawler; 11-12-2011 at 10:58 AM. |
11-13-2011, 08:41 AM | #8 |
Rock Crawler Join Date: Apr 2008 Location: Albany
Erin what kinda media? Like Glass beads or................ Evan |
11-13-2011, 09:34 AM | #9 |
| The pictured piece was thrown into my glass blasting cabinet filled with silicon carbide and shot for a second or 2. Way aggressive for plastic but I was just showing a sample of what you can do. If I had a lot to blast I would use some fine aluminum oxide.
