01-23-2012, 09:45 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Franklin, Va
| Iwata HP-CS acting up-noob-
Hello all! I have a Iwata Hp-CS airbrush that is acting up. When I push down on the trigger for air it does not spring back up. The air stays on unless I manually move the trigger up. What should I do to fix this? Thanks for the help! -Adam |
01-23-2012, 10:47 PM | #2 |
Quarry Creeper Join Date: Jan 2009 Location: Elko Co.
| Re: Iwata HP-CS acting up-noob-
Try oiling the plunger if that doesnt work you will need to replace the oring inside it. Hope that helps. Also after you oil it make sure to just shoot some air through it to make sure any extra gets cleared out... Reb |
Iwata HP-CS acting up-noob- - Similar Threads | ||||
acting jumpy... please help | krono7s | Axial SCX-10 | 17 | 06-02-2011 06:03 AM |
Iwata Madness... | Greatscott | Paint and Body | 10 | 05-24-2011 01:24 PM |
Iwata Air brush | Leeroy | Paint and Body | 7 | 06-23-2008 02:01 AM |
two batteries acting as one? | obijuan | Electronics | 2 | 07-02-2007 12:47 PM |
