02-04-2012, 10:05 AM | #1 |
| paint removal
I just got a used body an it is painted yellow on the inside. Is there a way to remove it? What can i use? Its spray painted...
02-04-2012, 11:23 AM | #2 |
Quarry Creeper Join Date: Sep 2007 Location: strawtown
| Re: paint removal
just paint it on the outside |
02-04-2012, 11:27 AM | #3 |
| Re: paint removal
Yeah I'm on that too... I just wanted to get the info to get some off around the windows an in the corners to give a rust or silver look for when the paint scratches.. trying to get the know how.
02-04-2012, 11:39 AM | #4 |
| Re: paint removal
I found carb cleaner works ,on accident... Doh! Spray some on a rag and just wipe the paint off. |
02-04-2012, 03:01 PM | #5 |
| Re: paint removal
Great info, thanks
02-04-2012, 05:53 PM | #6 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: paint removal
Brake fluid. Almost anything will make it foggy if you let it dwell for long...keep an eye on it!
02-04-2012, 05:57 PM | #7 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: paint removal
Dot 4 brake fluid.
02-08-2012, 04:52 AM | #8 |
Quarry Creeper Join Date: May 2011 Location: El Paso TX
| Re: paint removal
x2 on dot 4 works great might make the lexan hazy but once repainted you will not be able to see the haze |
02-11-2012, 09:26 PM | #9 |
Quarry Creeper Join Date: Oct 2007 Location: Sheboygan
| Re: paint removal
I used dot 4 brake fluid a couple weeks back to strip the paint from my entire body. It worked great. I was sitting in the brake fluid for a couple days and did not make it hazy at all.
02-11-2012, 10:56 PM | #10 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
Yeah I agree dot4 I never have had it make my bodies hazy and I let em set for a few days before attempting to remove the paint it takes a little elbow so be prepared to do some scrubbing J-bird |
02-11-2012, 11:33 PM | #11 |
Newbie Join Date: May 2011 Location: renton
| Re: paint removal
purple power does wonders let it soak for 24 hours and spray it off.
02-12-2012, 12:52 AM | #12 |
I also use super clean from Walmart on hard bodies it works very good but I've never used it on lexan maybe someone else has and can chime in.. As for hard bodies/styrene you can cover it and wait a day or two and wash it off an youre done no need to scrub it or anything works great on wild willy drivers too J-bird |
paint removal - Similar Threads | ||||
Paint Removal | J Mann | Paint and Body | 19 | 03-17-2010 02:21 PM |
paint removal | hende | Paint and Body | 20 | 12-19-2009 09:36 PM |
Paint removal | aashu | Paint and Body | 9 | 10-13-2009 04:48 AM |
Paint Removal | nico_6194 | Paint and Body | 0 | 11-10-2008 04:12 AM |
Paint removal help | spot me 2 | Paint and Body | 2 | 05-07-2008 07:04 PM |
