02-15-2012, 01:16 PM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
| Mounting XR10 'Hardline' body - Which posts to use?
I'm getting ready to paint and mount my Axial "Hardline" body for my XR10 rig. I was wondering if anyone could give me some feedback on which body posts worked the best for them? I currently have the shortest ones in place and it's hard to tell (since I haven't cut the body out yet, it's still clear) but it seems they may be a little short. Also, locating the front post seems not to big a deal but when located in the center of that area just in front of that molded 'hood scoop', it appears that the rear posts will fall partway in and out of that raised ridge that goes from front to back of the top center of the body shell. Will they stick out far enough to get clips on that way? The posts are pretty close to each other and there doesn't seem to be any way to widen them enough to be on the outside of that 'ridge'. Can anyone give me a hand?
02-15-2012, 02:09 PM | #2 | |
Pebble Pounder Join Date: May 2009 Location: Northern Virginia, USA
| Re: Mounting XR10 'Hardline' body - Which posts to use? Quote:
02-15-2012, 04:41 PM | #3 |
| Re: Mounting XR10 'Hardline' body - Which posts to use? |
02-15-2012, 05:16 PM | #4 |
Rock Crawler Join Date: Oct 2011 Location: smithville
Hey diggy, i put some white out on my body posts then put my body on which left the marks on the body, that way i could see where i wanted to drill so maybe that will help. Anyway i used the longest posts then have those almost all the way up because of the way i cut my body. If i put it lower it will hit the servo, heres a pic... |
02-15-2012, 09:24 PM | #5 |
Thanks Krawler23. Yeah I've used the old "white out" trick myself, more than a few times. On at least one occasion, I even snuck my wife's lipstick for the job when I ran out of "Liquid Paper". (hey it worked, true story!) LOL So you used the longest body posts eh? That's good to know. I can see why you did that from the pics. Nice job btw! I plan to cut my body along the standard lines, as molded by Axial, so I'm not sure if I'll need the longest ones but I'm beginning to think the shortest ones might be a little too short. Not sure. Anyone else have any thoughts or advice on which length would work best, or what you use? |
02-16-2012, 11:07 AM | #6 |
I don't have mine handy, but I believe I used the shortest ones, mounted at maximum length.
02-16-2012, 01:57 PM | #7 |
I guess the medium would be fine, why not just try a couple?
02-17-2012, 12:24 PM | #8 |
| Re: Mounting XR10 'Hardline' body - Which posts to use? Yeah, I think that's what I'm gonna do. With the feeback I've gotten, I see that even the shortest ones can be used but I shouldn't have to go any longer than the medium ones. It will be eazy enough to switch them up at any time. Thanks again. |
