stripping aluminum parts to the natural aluminum color looking to take it off an paint them.. tried a bunch of different things. so far nothing has worked.. any ideas? thanks |
Re: stripping aluminum parts to the natural aluminum color I've soaked then in Greased Lighting with good results |
Re: stripping aluminum parts to the natural aluminum color Original formula Easy Off Oven Cleaner. Greased lightning works real well. Made this about 4-5 years ago. http://youtu.be/FLvxMJ5_WZE |
X3 on the Greased Lightning. It works great. If you have access to a machine shop with a glass beading booth, that will produce the ultimate raw metal finish. So clean, so nice. Sent from my SGH-T959V using Tapatalk 2 |
Re: stripping aluminum parts to the natural aluminum color Keep an eye on the greased Ightning...and the easy off. You can discolor the metal real easy leaving it too long Greased lightning is the best though.... |
Re: stripping aluminum parts to the natural aluminum color I used super clean on my beadlocks because our parts stores didn't have greased lightning. Soaked for a while agitated every few minutes with a brush and worked like a charm. Took about 15-20 minutes to remove the anodizing completely. |
Re: stripping aluminum parts to the natural aluminum color oven cleaner real easy to get. didnt find Greased lightning yet.. see how it goes thanks |
Re: stripping aluminum parts to the natural aluminum color Bead blasting is the quickest method. I have a snall harbor freight cabinet that was cheap and works greaf. When i say small, it barely fits an 18" car wheel. |
Re: stripping aluminum parts to the natural aluminum color Quote:
Re: stripping aluminum parts to the natural aluminum color i got some thanks. 9 bucks for a gallon |
Re: stripping aluminum parts to the natural aluminum color been using this for a bout a hour now.. water is now dark brown.. seems to be having a hard time removing the color.. do i need to refresh it? im doing links, steering parts and 3 sets of bead lock ring thanks |
Re: stripping aluminum parts to the natural aluminum color That's a lot of parts to be marinating at once...as long as it's all submerged you should be good though. Stir/agitate it often. I ended up using a small wire brush to help it along. After a couple hours you may want to change out the juice If you can't get it all off (some spots are more stubborn then others) you can sand them down.getting progressively lighter in grit you can get then polished up like brand new. CAREFUL OF YOUR EYEBALLS WHILE WIRE BRUSHIN! |
Re: stripping aluminum parts to the natural aluminum color part started to go from the natural aluminum color to like a dark gray.. Yeah parser laying on top of each other. Where there were touching the color didn't come off at all |
Re: stripping aluminum parts to the natural aluminum color Will Greased Lightning work on anodized aluminum as well? (Greased Lightning can be found at your local auto parts stores) |
If you warm the parts up with a heat gun/hair dryer the anodizing comes off faster. It appends up the chemical reaction that attacks the aluminum |
Re: stripping aluminum parts to the natural aluminum color Cool. I stripped the anodizing off my rc10 a long time ago the hard way, sand paper, but was unsuccessful on the shock bodies, now i can go back and do those to match http://i972.photobucket.com/albums/a...4-17223055.jpg |
Re: stripping aluminum parts to the natural aluminum color anyone know why it changer the color of the parts? |
Re: stripping aluminum parts to the natural aluminum color ok got it thanks |
Re: stripping aluminum parts to the natural aluminum color Be careful when using over cleaner. It can actually eat away enough aluminum in a short time that it changes the tolerances on some parts. EG: I did some steering knuckles recently and the bearings are now a looser fit. The anodizing is a microscopically thin surface coating. As soon as it`s clearing, get those parts rinsed! |
