05-17-2012, 11:51 AM | #1 |
Newbie Join Date: May 2012 Location: Plymouth, MI
| Smoothing the edges?
After you trim the body, how do you smooth out the edges?
05-17-2012, 12:30 PM | #2 |
RCC Addict Join Date: Nov 2008 Location: Frederick
| Re: Smoothing the edges?
I use a Dremel with a stone drum. It also works to make the edges real clean.
05-17-2012, 09:42 PM | #3 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
I used sand paper. 100 grit to clean it up and then down to 600 to really smooth them out. They looked like they were "factory"...course I ended up cutting them off not too long after! DOH! Crappy pic but... Last edited by Mr.Joshua; 05-17-2012 at 10:02 PM. |
05-19-2012, 09:21 AM | #4 |
Quarry Creeper Join Date: Apr 2012 Location: So. Cal.
| Re: Smoothing the edges? What speed do you set your dremel at for this? Curious too why you prefer the stone drum over the standard sanding drum. Just cut out my first lexan body and it looks like crap, ragged uneven edges. Before I scrap the whole thing I'm gonna give the dremel a try.
05-19-2012, 11:32 PM | #5 |
Pebble Pounder Join Date: Mar 2012 Location: Madisonville
I've always used sand paper, and for those hard to reach areas I use something like thisTowerHobbies.com | FOR159 159 Fourmost Sanding Stick I can't find exactly what I've got but it has the profile like an airplane wing, round on one side flat on the other, kinda looks like a half tear drop. For long flat areas use a regular sanding block. If you cut carefully usually don't even need sanding. |
05-20-2012, 01:55 PM | #6 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
Make sure to used curved lexan scissors to trim the body, regular kitchen scissors will leave it pretty rough looking.
Smoothing the edges? - Similar Threads | ||||
Grinding/smoothing tools | tarmo120 | Tools, and Procedures | 0 | 03-04-2010 10:39 AM |
