Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Old FJ cruiser bodies made?
Old 08-31-2012, 04:15 PM   #1
Default Old FJ cruiser bodies made?
so i bought a tuber a few years ago that has a toyota fj body on it, i want to replace the body but im not sure what one, anyone know all the fj cruiser bodies made? it has toyota land cruiser stickers on it, and toyota grill sticker so i dont think its the bushwacker? well i think its the proline land cruiser body, but is that the exact name of it?
phase10 is offline   Reply With Quote
Old 08-31-2012, 04:40 PM   #2
THW
Default Re: Old FJ cruiser bodies made?
Posting a pic will help a ton.
THW is offline   Reply With Quote
Old 08-31-2012, 05:27 PM   #3
its the one with pho-diamond plating on the back corners.
Old 08-31-2012, 06:32 PM   #4
well i believe its NOT the tamiya if that helps. ive never seen the pro-line version.
greggreg2011 is offline   Reply With Quote
Old 08-31-2012, 06:39 PM   #5
I have the same one and if I remember its the Proline body but I dont remember what they called it
paleblue46 is offline   Reply With Quote
Old 08-31-2012, 07:50 PM   #6
So the entire grill is a sticker ? It looks just like the cr-01 bodies by tamiya . Still being made . If it is a proline it most likely like all the cool bodies they had . has been discontinued .
hellbounder is offline   Reply With Quote
Old 08-31-2012, 08:23 PM   #7
I think that's a Proline Land Cruiser body that got discontinued. Tamiya's FJ body set is more detailed...especially the grill area with headlights that pop out from the body not quite as flat in the pics. Tamiya's body also has a more detailed roof that juts out across the front of the windshield.
alexchen86 is offline   Reply With Quote
Old 09-04-2012, 05:30 PM   #8
looks just like the proline I am doing now, the lower grill and rear corners give it away.
jeepgod is offline   Reply With Quote
Old 09-04-2012, 06:24 PM   #9
Built, not bought
62PYRO's Avatar
That's the original Pro-Line LC body.They had legal issues so,it got modded to the bushwhacker body.Dimensiopns are the same so,either one will work for a replacement.
62PYRO is offline   Reply With Quote
Old 09-06-2012, 02:51 AM   #10
oh thanks! didnt know they were the same dimensions ill look into a bushwaker, the tamiya one is NOT the same dimensions correct?
Old 09-06-2012, 08:03 PM   #11
Built, not bought
62PYRO's Avatar
Get ahold of me tomorrow or Saturday.I have a Bushwacker you can try out to see if you want.
Old 09-07-2012, 06:50 AM   #12
cartronicshn's Avatar
correct, the tamiya is slightly shorter wb.
cartronicshn is offline   Reply With Quote
Old 09-07-2012, 09:48 AM   #13
PapaGriz Yo
Grizzly4x4's Avatar
The Proline FJ40 body had the hood latches at the front of the body and diamond plate at the back corners.
The Proline Bushwacker had the hood latches at the back of the hood.
I have both at home and they appear to be identical in all dimensions.
Like Cart said, the Tamiya is a bit different.
Grizzly4x4 is offline   Reply With Quote
Old FJ cruiser bodies made? - Similar Threads
cruiser bodies D.M.C. Paint and Body 4 09-14-2011 08:06 AM
FJ Cruiser bodies??? Zuk90 Paint and Body 5 04-23-2009 08:57 PM
