10-01-2012, 01:03 PM | #1 |
Rock Crawler Join Date: Oct 2011 Location: Warren
| Liquid masking tape.
Can you paint hobby grade liquid masking tape on with a paint brush and then trim around the windows and such? Has anyone done this with success? It says that you need to spray it with an airbrush. But, I dont have and airbrush to spray it with. I only really need it to mask off the windows. Thanks |
10-01-2012, 01:52 PM | #2 |
RCC Addict Join Date: May 2008 Location: Green Bay
| Re: Liquid masking tape.
Yes, it takes several coats, make sure it dries well between them. Not the best method but it does work.
10-01-2012, 04:51 PM | #3 |
Thanks. I figured it would the container says you can paint it on small areas with a brush. I guess I will be giving it a try.
10-01-2012, 05:25 PM | #4 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
You will have to clean the airbrush everytime really between coats so it does not clog up which is a pain. I would just put 3-4 good coats on with a regular paint brush and dry between each coat.
10-01-2012, 05:49 PM | #5 |
sounds good
10-08-2012, 12:36 AM | #6 |
Newbie Join Date: Jun 2012 Location: Australia
I've used it quite a bit and it works very well. You want to do a few coats and don't worry if it is fairly thick. However, you don't want blobs or significant differences in thickness. Try for even coats with out large ridges as these are harder to cut through. I typically do 3 coats and that is usually enough. I've never tried spraying it with an airbrush. I do have one but wouldn't think of trying it. The stuff is far too thick to spray well unless you tried with a spray gun with a 1.5mm or 2mm tip or something similar. When you cut, make sure you use a very shape knife and don't press too hard or else, you will score the paint or even plastic underneath. If you want to cover a large area, you are better off using masking tape, paper and frisket.
10-10-2012, 03:20 PM | #7 |
RCC Addict Join Date: Jul 2009 Location: Near Boston
I use this stuff a lot too. I have tried airbrushing it on but it is definitely not worth the effort. Just do a couple coats with a 1/2" brush. A quick tip, any creases or depressions you may want to do an extra coat cause if it is not thick enough in those areas it is a real pain in the a$$ to get off. (Think roll bars in short course bodies) |
10-13-2012, 08:39 AM | #8 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Liquid masking tape. Quote:
Use an old spray gun if ya got one. I usually use a touchup gun with a 2.5 tip at about 40psi. I shoot 3 medium coats & it's plenty...dry between coats with an old hair dryer. Hot air guns can bubble the mask. If you're gonna use a brush...just grab a handful of cheap foam brushes or 2" chip brushes & keep the coats light. Make sure you let each coat FULLY dry or you'll trap that moisture & it'll booger your paint job. It's an easy process & MUCH better than tape or those lame precut vinyl "graphics". J.D. | |
Liquid masking tape. - Similar Threads | ||||
Negative effects of liquid masking? | P3NGU1N | Paint and Body | 2 | 02-17-2010 12:15 PM |
How to remove adhesive from body (Left by masking tape) | MDcrawler72 | Paint and Body | 1 | 01-03-2009 12:05 PM |
liquid tape. | cammok5 | Paint and Body | 2 | 12-20-2008 04:22 PM |
Masking tape... | BagoXCAlum | Chit Chat | 7 | 05-22-2006 09:06 PM |
