Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: help with body pre paint prep
Old 10-14-2012, 10:37 PM   #1
Default help with body pre paint prep
Hello my name is Mike I just got my new trail finder 2 kit and need help I have the yellow hard toyota body and want to paint it right I need to know what grit I need to use for the best resolts and should I wet sand or dry what primer is best I have a can of selfetching primer is that ok for plastic and do I need to sand the primer if so what grit can I use testers modal paint for the trim or is there something better also anyone know where I can get the 3 strip decals for the body any info would help
fivel_976 is offline   Reply With Quote
Old 10-16-2012, 06:23 PM   #2
Default Re: help with body pre paint prep
Wet sanding the primer is definitely the better choice over dry sanding.
I would use either 800 or 1000 grit sand paper for the best results.
I would just use a standard primer.The Testors paint will be okay but I'm postitve that there are better brands of paint to use.
David
Crimson Rock Crawler is offline   Reply With Quote
Old 10-19-2012, 03:04 AM   #3
You should also wipe it with regular paint thinner or acetone just before painting, just make sure to dry it completely.This also preps the plastic for paint and it will stick better.
TNT1 is offline   Reply With Quote
help with body pre paint prep - Similar Threads
Body prep ? 1rcmonster Paint and Body 10 09-02-2011 04:04 PM
styrene/hard body paint prep Wicked_Jester Paint and Body 5 11-01-2009 09:41 AM
Tube Chassis Paint Prep rerock Tools, and Procedures 6 11-27-2008 05:20 AM
Best way to prep for paint? RockLord442 General Crawlers 3 01-02-2006 05:01 PM
