12-02-2012, 04:37 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: melbourne, australia
| filler for newbright hardbody
ive got a new bright jeep body and i have cut some rear spare tire mounts off. it has now left some small holes in the body and im wondering what sandable filler or bog i can use to fill the holes.
12-02-2012, 05:07 PM | #2 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
| Re: filler for newbright hardbody
Squardon products green putty - Green Putty Squadron Products MMD Tube 9050 New | eBay They make a red as well but the green seems to be easier to sand IMO. Depending on the holes you want to fill (maybe a seam) you can make a styrene putty body filler as well with some small chunks of styrene and some Tenax "glue" |
12-02-2012, 05:27 PM | #3 |
thanks for that ill see if i can find some at my lhs
12-03-2012, 05:23 AM | #4 |
Rock Crawler Join Date: Sep 2009 Location: In West Monroe,LA...yes,where Duck Dynasty is filmed
The Tenax solvent didnt work for me.I had to fill in a sun roof on a Nikko hard body with a piece of styrene.It wouldnt bond so i just went with CA then used red Bondo glazing putty.It worked like a charm |
12-03-2012, 05:53 AM | #5 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
X2 on the bondo glazing putty, I've never had an issue with sanding or it cracking later on down the road. It's also readily available at Walmart, auto parts stores etc.
12-03-2012, 10:20 AM | #6 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
I use ABS pipe cement since the NB bodies are made from ABS for more of the structural areas. It fuses to to body and is sandable once cured, making a very solid filler. For what your after, you could use the ABS cement or good hobby filler like Squadron or the Bondo automotive spot putty. I the the Bondo my self. Here's a NB JK roof I cut and sectioned for my Brute build using ABS cement |
12-10-2012, 12:47 AM | #7 |
will tamiya putty work?
12-20-2012, 06:20 PM | #8 |
Quarry Creeper Join Date: Jul 2010 Location: williams county
I've used the bondo brand, it works well for me on small areas, on larger areas I often have problems with shrinkage. I prefer 3M Green acrylic spot putty. Works great, it can also be thinned with alcohol to make a great pit filler . |
12-20-2012, 06:43 PM | #9 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
X2 on the Bondo automotive spot putty...That's what I'm using on my Jeep Brute build myself.
filler for newbright hardbody - Similar Threads | ||||
new, newbright JK hardbody! | STANG KILLA SS | General Scale Talk | 153 | 03-20-2008 04:32 PM |
