Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: Tamyia F150 replacement bodie
Old 08-22-2006, 04:10 PM   #1
TCS Team Manager
Fishmaxx's Avatar
Default Tamyia F150 replacement bodie
I have a Tamyia F150, and the body for kit is still NIB. Since it is discontinued am going to put the body up for now .
Any suggestions for bodies that bolt right up, and still look scale?
If you have a picture of a body on this kind of kit will you post it up?
Fishmaxx is offline   Reply With Quote
Old 08-22-2006, 05:57 PM   #2
BOOBICON
SPECIAL ED's Avatar
Don't be a pu$$y just run the body
SPECIAL ED is offline   Reply With Quote
Old 08-22-2006, 06:51 PM   #3
Team *
62PYRO's Avatar
Probably a stupid question but,what's the wheelbase on that?I only ask because I've never owned one.
62PYRO is offline   Reply With Quote
Old 08-22-2006, 08:10 PM   #4
Axial Team Driver
Brandon's Avatar
Fully Indi Hummer H2
Proline Ridez hummer h2 body. fits perfect! although its also disco'd, but still around not like the FJ's.
Brandon is offline   Reply With Quote
Old 08-22-2006, 08:26 PM   #5
Get off my lawn!
microgoat's Avatar
You can drop a Blackfoot body on there if you want ultimate scale, or a Parma Blackfoot clone if you want budget scale. You can pick up a beat BF on the Bay fairly cheap, and they clean up easily with a little sanding. The Parma shell, naturally, is pretty weak on grille detail but you can beat the hell out of it. Parma's also got a '67 F-100 with a photographic grille sticker that fits. Flip the rear arms around and you could put a Pro-Line C10 or F-100 on.
PYRO, about 10 inches.
microgoat is offline   Reply With Quote
Old 08-22-2006, 10:25 PM   #6
BOOBICON
SPECIAL ED's Avatar
From wheel nut to nut is ten inchs
