Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Liquid mask on paint?
Old 12-28-2012, 12:08 AM   #1
Default Liquid mask on paint?
Will liquid mask adhere to paint?
mlaier is offline   Reply With Quote
Old 12-28-2012, 05:46 AM   #2
Default Re: Liquid mask on paint?
as long as its clean,it should. apply it in thin multiple coats
stanmondz is offline   Reply With Quote
Old 12-28-2012, 07:10 AM   #3
Should be able to remove it without causing to many problems also.
BC-Brian is offline   Reply With Quote
Old 12-28-2012, 08:13 AM   #4
Cool I'll give it a try. Thanks!
Old 12-29-2012, 07:47 AM   #5
Its a HARDKNOCKZ Life...
HARDKNOCKZ's Avatar
Be careful with this. Some spray masks are more unforgiving than others. I personally wouldn't apply spray mask to any lexan lid painted with water based paintes like Faskolor. I've gotten away with it but have found that the paint can flake if there's ANY edge for the mask to grab onto.
Good luck.
HARDKNOCKZ is offline   Reply With Quote
Old 12-29-2012, 08:57 AM   #6
Thanks for the info. I'll be using this on aluminum body panels, that has been primed with self etching primer, paint primer, and base coat is down..
Thanks again,
Mike
Old 12-29-2012, 08:58 AM   #7
Oh yeah, this will be on my Chaotic Mini Chassis.
Old 12-29-2012, 09:27 AM   #8
HARDKNOCKZ's Avatar
What kinda paint you using? If its HOK or a like urethane...use a coat of SG100 or another intercoat clear. It'll help protect the base coat from getting contaminated. You wont see it but if you plan on clear coating yer job...you can see exactly where the spray mask was used in a lot of cases. I only use spray mask as an initial system for this reason. Once I hve base down...I go to transfer tape.
Old 12-29-2012, 01:03 PM   #9
I'm using Testors one coat laquer for all finish colors..??
Will I be alright or should I just use tape instead?
Thanks!!
Mike
Liquid mask on paint? - Similar Threads
Liquid mask? Onebdgti Paint and Body 5 01-02-2012 12:00 PM
Liquid mask: First try. RIG_RIDER Paint and Body 15 05-12-2011 10:13 AM
liquid mask foolish 1 Paint and Body 10 09-06-2010 04:36 AM
liquid paint mask........... bob1961 Paint and Body 9 06-24-2009 10:38 PM
liquid mask Nub-4-life General Crawlers 20 01-15-2007 06:43 PM
