01-28-2013, 05:44 AM | #1 |
Quarry Creeper Join Date: Aug 2006 Location: Palm Harbor
| Sticker Help (not the water ones)
I need some advice on the cut out stickers, not the ones that come off with water but the ones you have to cut out and place. I want to be able to work with them a little (slid them if needed) would a water/soap mixture mess them up? Would they still stick after this? Thanks Bret |
01-28-2013, 06:23 AM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Sticker Help (not the water ones)
I use water and rubbing alcohol mixed 50/50. Spray the body and the sticker (sticky side) and let site, then place and squeeze out the mixture and air bubbles with a credit card or similar.
01-28-2013, 02:24 PM | #3 |
Newbie Join Date: Jan 2013 Location: Boise
Hey I'm new to the forum but not new to RC and/or vinyl application. (posting up to get to classified level too lol) the alcohol can work but may have a tendency to disrupt the adhesive depending on what vinyl your using. on a small application like RC dry is always better since your adhesive contact will be so small as compared to maybe a 1:1 application, but if you do need to go wet I'd say 3 parts clean water to 1 part windex. make sure all surfaces are clean and wipe with the cheapest paper towels you can find (more $$ = more additives like aloe, etc... and NO BLUE/SHOP RAGS, even the brand new rags will have oil/dye in them that will hinder the adhesive) |
01-28-2013, 07:07 PM | #4 |
Thanks for the replies. Will these methods allow for a little movement if needed?
02-04-2013, 01:32 PM | #5 |
Yes both will allow for movement, more alcohol content = faster drying time but don't forget to factor in surface and ambient temps as well...
02-08-2013, 09:09 AM | #6 | |
Pebble Pounder Join Date: Jan 2013 Location: Gilbert
| Re: Sticker Help (not the water ones) Quote:
You have a good point with the alcohol and could discolor the decal as well, dependent on use. I work for a transportation company and we use a soap (non-gritty) and water mixture to lightly spray the surface to allow movement and time to adjust to the position you desire. A credit card or hard plastic flat edge (without sharp edges) works great as well. What bubbles aren't removed with that technique can be removed by leaving it in the sun dry and hopefully remove them. Just don't get over zealous with the soap and water, if you use too much it will be tough getting it to stick. | |
02-08-2013, 02:01 PM | #7 |
Rock Crawler Join Date: Feb 2012 Location: NORTH SYRACUSE N.Y.
There is a product designed for this , its called RITE -ON ask a local vinyl shop or t=you local auto body supply shop , it also might be available on line I never looked but its the best stuff I have ever used . It does not effect the decal or the adhesive .
02-08-2013, 02:10 PM | #8 |
Rapid Tac is also awesome stuff and I would personally recommend it for any long-term application that will be exposed to outside elements for any extended duration. They have a whole line of cleaners, adhesive removers, and application fluids for different surfaces,vinyls and temperatures. I haven't used the Rite- but if its not available you'll be safe with Rapid Tac as well! jjwiggs - Being in Gilbert (AZ I assume) it might be worth using one of these application fluids on your next application, I know it seems crazy but i know the folks at Rapid-Tac have tested the long term effects and their product definitely decreases the chance of vinyl and adhesive failure due to extended sun and heat exposure! |
Sticker Help (not the water ones) - Similar Threads | ||||
sticker help for a newbie!! | rc dreemer | Paint and Body | 7 | 04-15-2011 10:10 AM |
Brushless water run...look out lots of flying water | Dogbreath | Videos! | 12 | 11-27-2010 12:50 PM |
