12-12-2006, 01:37 AM | #21 |
Well it's not working to well with White pearl. It's also living the body all cloudy.
12-12-2006, 03:39 AM | #22 |
RCC Addict Join Date: Feb 2005 Location: Guam
i used a rag to keep it soaked at all the time i was stripping it and i would apply more brake fluid with a brush every 40 mins. hope that helps |
01-08-2007, 05:57 PM | #23 |
Pebble Pounder Join Date: Dec 2006 Location: Trevorton
I used Easy Off... it took off most of the paint but seemed to leave the Lexan real weak... fragile... wont do it again... just my 2 cents...
01-08-2007, 06:12 PM | #24 |
Newbie Join Date: Jan 2007 Location: BeanTown
I've heard of using nitro wash , never used but heard of it more than once
01-29-2007, 09:26 AM | #25 |
Newbie Join Date: Jan 2007 Location: Edina
| stripping paint
Does it work on lacquer base paint and /or water base paint.
01-31-2007, 01:30 PM | #26 | |
Pebble Pounder Join Date: Oct 2006 Location: Enterprise
01-31-2007, 01:33 PM | #27 | |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
01-31-2007, 06:20 PM | #28 |
I joined the Band! Join Date: Dec 2006 Location: out of my mind
I hope everyone is Stripping paint off bodies only if they missed up in painting it. That seems like a lot of work just to repaint a old beat up body.
02-04-2007, 09:45 AM | #29 |
Rock Stacker Join Date: Mar 2006 Location: plainfield
ok so basicly, wats a good, CHEAP, paint remover?
02-05-2007, 08:23 PM | #30 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
3-DOT brake fluid like used in your car. 1. Will remove all paints even silver. 2. Will not fog the lexan or melt it or anything else. 3. It's CHEAP! Here's how: Get eye protection! 1. Pour some brake fluid in the body. 2. Take a rag and smear it around so everything has a nice thick coat. 3. Watch TV for like 5 - 10 min, time varies on thickness of paint. 4. Wipe the paint off. 5. Repeat process till the paint is gone, use a tooth brush or Q-tip for tight areas. 6. The body will be just as clear as it was new, (except the scratches from wrecking it). 7. Wash the body with your choice of soap and warm water. 8. Scuff it with a green scrub pad, wash, dry, and paint! I've used this method on old and new bodies. From 1:8 scale to the Micro-t bodies. Before: After: Also for those who wondered how I got a purple Micro-T, LOL. Last edited by BrockGrimes; 02-05-2007 at 08:26 PM. |
05-02-2007, 05:34 PM | #31 |
Pebble Pounder Join Date: Apr 2007 Location: Anchorage
Does ordinary paint thinner ruin the lexan?
10-10-2007, 10:23 PM | #32 |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
I've gotta big utility sink downstairs in my laundry room, is it safe to put brake fluid down the pipes or does that stuff need to be done outside?
10-11-2007, 02:47 PM | #33 | |
RCC Addict Join Date: Mar 2006 Location: Xxx
| I would assume yes , Paint thinner is some nasty stuff. My guess is it would cloud the lexen Quote:
I'm not sure if you can dump that stuff down sanitary drains. | |
10-11-2007, 03:33 PM | #34 |
Newbie Join Date: Oct 2007 Location: SoCal
ideally all of these chemicals should be disposed of properly! ie hazardous / chemical waste dept at local dumping facility. -quote "my dump is like 80 miles away!! am i suppoesed to go everytime i gotta get rid of a little oil?" doing the right thing isn't always easiest, and pour into a larger container and dump when full. also take ALL your toxic **** to dump at the same time! tires, batteries, printers, monitors, oils, paints etc etc. my 2.....4 and 6 sense. gonna try brake fluid tonight to clean some old bodies.... thanks guys!! |
06-05-2009, 11:10 AM | #35 | |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
09-21-2009, 07:02 PM | #36 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
| Quote: thank you I will give it a try |
09-21-2009, 08:06 PM | #37 |
Pebble Pounder Join Date: Aug 2009 Location: Lost in what was America
I was always curious about the whole paint removal concept. I never knew walmat would take your old oil though.
09-23-2009, 09:23 AM | #38 |
Quarry Creeper Join Date: May 2006 Location: Taylorsville
brake fluid sure wouldn't work for me :( i got an old 8ight-e body i'm wanting to make clear and repaint....i have a brand new body, but it's getting professionaly done, and i want a new practice body paint job |
09-23-2009, 09:34 AM | #39 |
Newbie Join Date: May 2009 Location: Albuquerque
Does this still apply to water based paints like Parma Faskolor? or is there a different method recommended for this? Sorry if it's a newb question, but I'm still a newb. |
09-23-2009, 07:11 PM | #40 |
Quarry Creeper Join Date: May 2008 Location: Out in the country
| Nitro wash |
