09-23-2009, 07:25 PM | #41 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
You know, I hate to say this but for the amount of money you guys are investing and time to do it, wouldnt just buying a new body be better anyways. FYI: Parma airbrush paints and all water based paints will come off soaking in very hot water after about 2 hours, it generally takes about 2-3, 2 hour soaks to get 99% of it. and yes with Brake fluid or boiling off the paint it will leave the shell cloudy, but most of the time if you paint it close to the same color it will look like a new shell because paint fills the scratches. Now that should also apply for faspearls and fasmetallics to the best of my knowledge. |
09-24-2009, 08:16 AM | #42 | |
It works when you have body you can't buy anymore. | |
09-24-2009, 09:48 AM | #43 |
Its still good information for anyone that wants to learn to strip paint reguardless of how old the thread is.
09-26-2009, 06:02 PM | #44 |
Pebble Pounder Join Date: Feb 2009 Location: here
finger nail polish remover works realy good and no foging.
09-26-2009, 06:38 PM | #45 |
09-26-2009, 06:59 PM | #46 |
I just had to strip my wifes new Slash body completely bare after her failed attempt of painting for the first time ever (used almost a whole can! Paint on the outside too! ). Brake fluid and a old washcloth took it all off, metallics too. No haze, very few scratches. After the repaint it looks like new. |
09-30-2009, 01:10 AM | #47 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
What can I use to remove lexan paint that I brushed on (thin lines) ? I have tried plastic paint thinner, brake fluid, Easy off. only some area have removed some paint. This was just my 1st of 4 steps of painting my new body |
09-30-2009, 02:20 AM | #48 |
Newbie Join Date: Sep 2009 Location: NSW australia MATE!
you wont get the paint off good enough to be re painted and the paint actually staying on. just get a new body. |
01-17-2010, 07:18 PM | #49 |
Newbie Join Date: Jan 2010 Location: palmerton
| thanks
just bought a used axial with ugly paint job cant wait to strip it off. thanks for the info everyone
01-17-2010, 07:24 PM | #50 |
Rock Crawler Join Date: Apr 2009 Location: bend
i could have used this info a few weeks back
02-02-2010, 07:14 AM | #51 |
Newbie Join Date: Jan 2010 Location: quakertown
thanks for that info
02-02-2010, 08:50 AM | #52 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
I am doing my scaler body and didn't lkke how it ended up. It stripped pretty easily with brake fluid...I had just painted it the night before so I guess it was still soft. Other times I have tried it left the body looking cloudy. |
03-21-2010, 08:02 PM | #53 |
Newbie Join Date: Jun 2009 Location: whitehall
what about goo gone?
04-08-2010, 07:25 PM | #54 |
Quarry Creeper Join Date: Feb 2010 Location: Duluth
I was in Fastenal a couple of days ago and they had a bunch of stuff on clearance (they are getting rid of stuff they don't sell much of) and I found Doradofix 1400 FOR $7.00 I painted some scrap pieces with 6 different paints and let it cure for 3 days then applied the stripper 5 minutes and the paint wipes right off. no scrubbing, brushing, ect. It also has no smell or fumes that i can tell. and the lexan is nice and clear. UPDATE: used it on a body that has been painted for a while, and it took several applications, but it did come off nice and clean. Last edited by thumper68; 04-09-2010 at 02:43 PM. Reason: update |
04-09-2010, 04:00 PM | #55 | |
Rock Stacker Join Date: Oct 2009 Location: beaverfalls
non acetone nail polish remover will remove the paint with no fogging | |
04-20-2010, 09:58 PM | #56 |
Newbie Join Date: Apr 2010 Location: Denver
Acetone will strip paint. It will also cause what seem like stress cracks. You can use it on anything except an edge. The edges must be more porous???The hazing of the body is not visible after painting. I tried acetone yesterday as an amateur rc painter, got a little on the back window of my bug, decided to wipe everything except the rest of the windows. The paint came out waaay better than I expected. None of the haze or minor scratching I created cutting the body and sanding the edges was visible. Now I've read this thread and know what everyone is doing I will try the reccomended products next. FYI acetone will remove anything fresh quickly. You just need to make sure the cloth is not dripping wet. Lightly saturated it will not create the edge stress cracks unless you continually rub an area. dadi |
04-20-2010, 10:02 PM | #57 |
Ps avoid windows. Once hazed I used black sharpie to cover the window. Once it dried I took a cloth covered in alcohol and dabbed the window. It came out looking like window tint. Cool. Thought I would need to paint it black after the hazing.
04-21-2010, 11:29 PM | #58 | |
Newbie Join Date: Dec 2009 Location: Central MO
It doesnt matter if you saturate a rag or dump it in a body. When the slightest bit of acetone comes in contact with bare lexan it will start melting it!!! This is why you get a haze or fog on the lexan as the surface has been eaten away. If you want to remove acrylic based paints Isopropoly Alcohol 92% works really well. Get yourself a tub slightly larger than your body and dump the alcohol directly into the shell. Let it sit for 10-20 minutes then whipe clean with a paper towel. If you are using enamel or laquer paints the alcohol will work on this as well but it has to be done in a short time frame after being sprayed! If either paint is allowed to cure to long the alcohol trick will still work but your lexan will become tinted from the color you sprayed. To remove the tint you can go to your local auto parts store and get a bottle of 3M Plastic restore. This is a micro scrubber product that will remove scratches from headlights, tail lights and other plastic surfaces on a vehicle. It will do the same thing for your shell. With all of this said. I think I would get a new shell or simply run the one you messed up on until it is beat to death then try again!!! | |
07-11-2011, 05:23 PM | #59 |
Rock Stacker Join Date: Sep 2009 Location: chehalis
D.O.T 4 brake fluid works the best out of all the types out there
07-11-2011, 10:11 PM | #60 |
Newbie Join Date: Aug 2005 Location: Pittsburgh
Try Mineral Spirits. I had a prepainted body that had some tough paint on it. Nothing but acetone would work, but that crazes the lexan. Had a can of Goo Gone (basically mineral spirits) and the paint came right off. Safer than Easy Off and a lot less messier than any brake fluid. After using the mineral spirits clean with alcohol then soap and water. Will look brand new. Last edited by fourxblz; 07-11-2011 at 10:15 PM. |
