04-10-2013, 02:47 PM | #1 |
Newbie Join Date: Apr 2013 Location: In a van down by the river.
| Anti Gloss
Would anyone be able to point me in the direction or give me some tips on painting a Dingo Axial body? I know there are extensive guides and tips on painting a body. More specifically I am wondering if there is a way to paint it black from the inside without having the gloss look from the shell itself, as in is there some sort of coating I can put on first or a coating I can put on the outside? I'm looking for a flat or military black color. I realize I could paint the outside but it will scratch... Thanks in advance! ZJ |
04-10-2013, 02:54 PM | #2 |
| Re: Anti Gloss
A few coats on the outside will be tough to scratch off. You could paint both the inside and outside so it won't be as noticeable when it does scratch. |
04-10-2013, 03:00 PM | #3 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
| Re: Anti Gloss
i paint mine on the outsides with self etching primer first, 2 coats of that and 3 or 4 of the color you want, in your case flat black,, and it will hold up just fine,, if it scratches it looks scale buddy!
04-10-2013, 03:07 PM | #4 |
Rock Crawler Join Date: Nov 2006 Location: Holland
| Re: Anti Gloss
PS-55 (Tamiya) will give you the look you're after. Black or dark grey (for lexan) on the inside, PS-55 on the outside. |
04-10-2013, 11:55 PM | #5 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
| Re: Anti Gloss
Wet sand the outside of the shell with 600-800 grit.
04-11-2013, 08:26 AM | #6 |
Quarry Creeper Join Date: Apr 2012 Location: Missouri
| Re: Anti Gloss
There is flat or dull clearcoat you can paint the outside with |
04-11-2013, 08:31 AM | #7 | |
| Re: Anti Gloss Quote:
I picked up[ some of that Clear Coat but ended up not using it because the paint on the outside came out mat enough. | |
Anti Gloss - Similar Threads | ||||
gloss varnish for lexan spray? | truebrit | Paint and Body | 0 | 06-21-2011 02:51 PM |
1814 high gloss enamel overcoat? | eyeopenher | Paint and Body | 3 | 12-21-2010 02:13 PM |
Anti-Squat ? | Fishmaxx | General Crawlers | 5 | 06-20-2004 10:05 PM |
