Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: Removing body holes on lexan bodies
Old 09-28-2006, 03:18 PM   #1
Default Removing body holes on lexan bodies
Mods: Feel free to move this thread but I didnt think anyone in the Newbie section would know....
Does anyone know if there is a thread on hiding / filling body mounting holes in lexan? I tired searching and didn't find anything.
I usually get new bodies but now I have a surplus of old bodies laying around and I would like to recycle some of them... I thought about shoe gooing the holes closed using lexan circles from a hole puncher and painting the body on the outside.
I know that regular paint will crack and flake off because the lexan is flexible but there are a lot of Krylon type paints out the that might not... I was thinking about flat black or olive drab – nothing fancy….
Any ideas??
Thanks,
mr.maxx is offline   Reply With Quote
Old 09-28-2006, 03:56 PM   #2
Well a guy I work with accidently drilled the pre dimpled holes instead of the ones he marked on one of his race bodies, and all he did was get some Stick-on MonoKote that was the same color, not the iron on type and put htat over it you couldnt even tell it was there. Or just cover it with a decal.
TMXONR is offline   Reply With Quote
Old 09-28-2006, 04:44 PM   #3
Powered by Awesome
TwistedXT's Avatar
sticker it up like special eds helmet!!!!!
TwistedXT is online now   Reply With Quote
Old 09-28-2006, 05:57 PM   #4
Get off my lawn!
microgoat's Avatar
Cover the hole with a sticker you don't care about. Then hit the hole with some Shoe Goo and let it dry overnight. Peel the sticker off. If you did it right, the hole will be either gone or so hard to see that you'll have to look for it.
If you did it wrong, fawk it, try again.
microgoat is online now   Reply With Quote
Old 09-28-2006, 07:47 PM   #5
I like that idea... I will give it a try!!
Thanks for the ideas.....
Old 09-28-2006, 09:39 PM   #6
Location: Hutto, Tx./Stuck between a rock and a hard place.
Automotive paint works good on outsied of rc. I re-did a s2000 body i got, it was ghey, i couldnt get the paint off the inside, so, i scotched the outside then painted.
go here and scroll down to the car:
http://melloyellodesigns.com/2.html
i would upload the pix right now to photobucket, but, no need. And ive let my freinds bash the hell out of the body too, no flaking, just deep scrathces.
Mello_Yello is offline   Reply With Quote
Old 09-28-2006, 09:48 PM   #7
That is a good idea
Mad Scientist is offline   Reply With Quote
Old 09-29-2006, 09:38 AM   #8
Official Scale Nazi
pigeonfarmboy's Avatar
Just make sure to use a Laquer based paint instead of enamel.
pigeonfarmboy is offline   Reply With Quote
Old 09-29-2006, 11:17 AM   #9
Rockpiledriver's Avatar
Yep, I've used this method several time to restore old bodies. Works great.
Rockpiledriver is offline   Reply With Quote
