07-21-2013, 05:58 PM | #1 |
Rock Crawler Join Date: Jun 2013 Location: Cincinnati
| Need some NewBright help
I was very lucky and I picked up this 1/8 F150 for $40 IMG_6881 by sgtbforza, on Flickr Before I do anything to mess this body up I have a few questions for you guys that have worked with these bodies before - As you can see the headlights/tailights are a bit faded and lackluster IMG_5385 by sgtbforza, on Flickr IMG_3404 by sgtbforza, on Flickr What is the best way to restore them? Do they come apart easily? Sorry to ask these simple questions but I will probably never get another one of these bodies I want to do everything right. |
07-21-2013, 06:00 PM | #2 |
| Re: Need some NewBright help
Also, do most people remove the "new bright" from the windshield or paint over it? If you do remove it, how?
07-21-2013, 06:52 PM | #3 |
Quarry Creeper Join Date: Apr 2013 Location: GODS COUNTRY,LOUISIANA
Use the headlight stuff from auto zone
07-21-2013, 07:23 PM | #4 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
spray clear, will bring the tail light luster back for sure, but the headlights would look best if just polished them, like with some FLITZ or some light buffing compound
07-22-2013, 07:44 AM | #5 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
Nice find sir! Just polish up the headlights with some light buffing compound, worst case scenario you can clear coat them. To remove them, I use a soldering iron and heat up the plastic on the backside and they'll just push right out no problem. As for the NEWBRIGHT on the windshield, use some alcohol or fingernail polish remover.
07-22-2013, 02:58 PM | #6 |
Thanks for the replies fellas! I decided to grow a set and start prying things off, worked out pretty well - broke a tab off of a headlight lens but a little shoe goo and nobody will ever know. Now I need to buy an scx10 to go under it haha
07-22-2013, 03:26 PM | #7 |
Also, im considering picking up the F150 crewcab lexan body for the savage to hack the windows out...not sure how that will work out though.
07-22-2013, 04:23 PM | #8 |
| Re: Need some NewBright help Don't do that. Just buy some clear styrene (Ebay or Hobby store) and cut it to fit. That'll be ALOT cheeper. You can use .20 or .40 depending on how thick you want it to be. |
07-22-2013, 06:16 PM | #9 |
| Re: Need some NewBright help |
07-22-2013, 09:48 PM | #10 | |
Newbie Join Date: Jul 2013 Location: Bahama
| Re: Need some NewBright help Quote:
I tried finger nail polish remover (without acetone) after reading that it worked good for that. It did remove the letters, but it melted the white liquid into the windshield. Further use of nail polish remover did nothing, alcohol did the same thing to the letters. They both melted the windshield and gave it a very rough texture. I had to sand the windshield to fix it Further advice, I have the Raptor body. Im removing the stickers and everything. Alcohol, fingernail polish remover, and liquid wrench eat threw the paint very fast. Do not use them on the paint. Ive found that its best to peel the stickers off the best you can by hand, soak the exposed paper backing in liquid wrench (i squirted some in a bowl and used a Q-tip to soak the paper, making sure to avoid getting it on the paint,) then peel off the paper backing that sticks to the body (itll come off very easy after it soaks for a minute.) Then, for sticky residue, Neverdull worked great. If you rub it too much, itll slowly take off paint, but i never had enough come off to see a difference. The paint on these Newbright bodies seems to be very sensitive to chemicals. Last edited by fcfordlord; 07-22-2013 at 09:55 PM. | |
07-23-2013, 07:50 AM | #11 | |
I used regular rubbing alcohol from Walmart on my Newbright Jeep and it came off without any issues at all and the windshield is as clear as can be. You don't want to soak it, just get some on a rag and gently rub it off . I have only heard of guys using the remover and such, never tried it myself. | |
07-23-2013, 11:53 AM | #12 | |
Maybe a rag would've worked better to soak up the lettering before it could soak into the windshield, or maybe Newbright is just using a different plastic for these Ford bodies? I noticed it's very soft compared to all the other Newbright bodies I've dealt with in the past (two different style 1/6 scale H2's, 1/6 scale CXT, smaller scale but older Jeep) | |
Need some NewBright help - Similar Threads | ||||
another newbright tj ha ha | kaneohecrawler | Axial SCX-10 | 15 | 01-16-2013 08:06 PM |
NewBright help.... | SGTHopkins | Newbie General | 3 | 11-16-2009 05:16 PM |
what is the wb on the newbright fj | 4x4boy | General Scale Talk | 2 | 01-27-2008 06:11 PM |
newbright | tuber53 | General Crawlers | 3 | 05-13-2007 03:27 AM |
