09-01-2013, 01:05 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: opp
| fiberglass question
Hi all.I'm in the slow process of building a nb avalanche.I've had to cut the grey trey piece that holds the interior.I'm curious if fiberglass would bond to it or not before I tried it and screwed it up.I've searched and can't seem to spot the info I need.any help is appreciated
09-01-2013, 04:16 PM | #2 |
Rock Crawler Join Date: May 2013 Location: plains
| Re: fiberglass question
i dont think fiberglass would adhere to plastic. i could be wrong but ive talked to my lhs about using like the fiberglass cloth patches to splice my hilux cab back together and he said he didnt think it would stick to each other.
09-01-2013, 07:33 PM | #3 |
Thanks for the help man.I may have to use sheet metal
09-01-2013, 08:25 PM | #4 |
Can u put up a pic maybe there's another idea. I'm not familiar with this piece u cut.
09-02-2013, 05:59 AM | #5 |
Rock Crawler Join Date: Nov 2006 Location: Holland
| Re: fiberglass question |
09-02-2013, 06:03 AM | #6 |
09-02-2013, 11:23 AM | #7 |
Hmmm welding it together sounds fun might have to try it on some cutoff scrap
09-02-2013, 05:25 PM | #8 |
Quarry Creeper Join Date: Feb 2013 Location: Northcentral Wisconsin
actually, you CAN use fiberglass on plastic - depending on the type. the "oily" types - not so much, but the dryer, non-oily types - yes, it does work I have successfully used fiberglass to repair a motorcycle fairing that was pretty heavily damaged from years of abuse. you do have to rough it up (med/coarse sandpaper) to provide something for the resin to grip onto - just like you would for any other application. mixing the resin/hardener properly is the key to good fiberglass. too little hardener and it wont cure right and remain slightly tacky indefinitely, too much hardener and it will start setting up too quickly, not giving you enough time to get the glass cloth set properly. |
09-02-2013, 06:26 PM | #9 |
I have done the same on a set of quad fenders.just scared to mess up the trey since they don't sell them anymore.reason I thought about metal. I'm at a stand still
09-03-2013, 07:54 AM | #10 |
have you considered building a completely new tray out of styrene? Styrene is not that hard to work with, and is very customizable. Using the measurements of what you currently have/need it would be relatively easy to build a new tray completely from scratch. (BTW - if you have cut up the original tray, you have already "messed it up" ) |
09-03-2013, 11:43 AM | #11 |
You make a good point heartless. I've researched styrene a little bit.I'll look deeper into it.thanks for the help
10-28-2013, 06:46 PM | #12 |
Newbie Join Date: Jul 2013 Location: whitehall
Plastic welding. hmmm...... Sounds really fun. I will be researching that for sure!
fiberglass question - Similar Threads | ||||
Fiberglass?? | j182j | Tools, and Procedures | 26 | 12-01-2009 12:27 AM |
Fiberglass Molding | Mad Scientist | Chit Chat | 5 | 04-15-2007 06:54 PM |
Fiberglass help | bigtiresrbetter | Paint and Body | 2 | 01-19-2007 06:03 PM |
Fiberglass FJ-40 and CJ8 | dezfan | Chit Chat | 2 | 01-04-2007 11:30 AM |
any one know how to work with fiberglass | Rokclod3Krawler | Chit Chat | 9 | 10-08-2004 09:03 PM |
