10-15-2013, 06:30 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: Montreal
| Clod vs Blackfoot bodies
I kind of messed up my clod body while trying to fill the scoop hole on the hood...it's not totally dead but the middle line is pretty messed up...I was wondering, if you put a blackfoot side by side with a clodbuster body...are they the same height? I actually only need the front cab as I have a truggy so the wheel well would probably almost be the same, but if it's a little higher might look weird vs the truggy cage behind...it's my first experience with styrene and putty so I wasnt really expecting a pro job...I'll still try to fix it but I might go with a ford body...more original and no hood to fill! Thanks |
10-15-2013, 09:50 AM | #2 |
| Re: Clod vs Blackfoot bodies
I think the Blackfoot body is not as wide.
10-15-2013, 10:22 AM | #3 |
Rock Crawler Join Date: Oct 2012 Location: Vermont
I think my Blackfoot Xtreme cab is about 7" wide at the widest point. I can let you know the exact measurements later if you want. I was actually curious about this too, if there is another cab that's close in dimensions.
10-15-2013, 11:21 AM | #4 |
I can measure my clod body as well |
10-15-2013, 11:23 AM | #5 |
6 3/4" for the original blackfoot.
10-15-2013, 05:49 PM | #6 |
My Blackfoot Xtreme cab measures at its widest and longest points: Width: 6-3/4" (middle of doors - widest point) Height: 4-1/4" (rocker panel to top of roof) Length: 8-5/8" (middle of grille to back wall of cab) |
10-16-2013, 04:21 AM | #7 |
My clodbuster is 7" between the 2 fenders and 5" high Sent from my Nexus 4 using Tapatalk |
10-16-2013, 04:45 AM | #8 |
| Re: Clod vs Blackfoot bodies |
10-16-2013, 06:00 AM | #9 |
i'll check that tonight!
10-16-2013, 07:01 AM | #10 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
You could make a hoodscoop for the Clod. No hole to fill then.
10-16-2013, 09:15 AM | #11 |
hmmm that could be interesting! for this one, it's a little too late, but I have another one, that I will keep for the sunday rides! this one will just get the bump sanded down!
10-16-2013, 01:16 PM | #12 |
10-17-2013, 07:05 PM | #13 |
A friend of mine got half round styrene sticks....very small, I might use those! Sent from my Nexus 4 using Tapatalk |
Clod vs Blackfoot bodies - Similar Threads | ||||
lots of tamiya clod/hilux/blackfoot bodies cheap look | dolphenwulf | Chit Chat | 35 | 09-13-2011 08:03 PM |
Blackfoot and Lunch Box Bodies | bigdodge88 | Paint and Body | 7 | 10-31-2008 10:18 AM |
