Custom body pin mounts 4 Attachment(s) Attachment 259358 We finally got our body pin mounts added to the site. These are so much smaller than the traditional Traxxas style hood pin setup. They are also ideal when you may have an inner fender setup that is held on by the outer body panels, and always drops out of place when removing the outer panel for access. These keep the inner fenders held in position at all times, only require and 1/8" hole in the body, and a can be modified for a very low profile. We usually drill the body holes a little tight and just clip the body on, completely elimination the need for body clips as well. You can add body clips for added security though. Steel construction for durability. 3mm threaded shaft Installs with common 5.5mm nut driver, same as used for 3mm nuts .125" head diameter on pin Attachment 259359 Holding inner fender in place Attachment 259360 Low profile, easy on the eyes Attachment 259361 Purchase here http://carterfabmachine.com/?product...body-pin-mount Thanks, Clay |
