10-21-2013, 09:16 PM | #1 |
Newbie Join Date: Oct 2013 Location: Calgary, Canada
| Painting the outside of my lexan body.
Hey all! I am planning on painting the exterior of my Scx10 rubicon... A couple questions: 1. I am planning on usin Tamiya PC spay paints....do I need to prime the body ahead of time? What primer should I use if so? 2. Since the finish with any polycarbonate paint will be matte, I assume decals will not stick. correct? 3. I will need to mask the windscreen. Any recommendations on a spray mask? 4. I would like to paint some of the interior details by hand (mainly to preserve the details...steering wheel, interior decals etc...). Do the tamiya sprays have matching paint pots as well? Thanks for any advice! Greg Last edited by Greg2K6; 10-21-2013 at 09:19 PM. |
10-21-2013, 10:34 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
| Re: Painting the outside of my lexan body.
You do not have to prime the body if you are using the Tamiya ps paint. If you have not pulled the outer protective coating off the body then you can cut around the windows and use the film as a mask, if it does not then you can use any masking tape, i like the green tape for painting but it is more expensive so you can get away with the tan tape. Decals should stick on just fine as long as it is s pretty smooth surface. Tamiya does have small containers that you can use or you can just spray the can paint into something and then use a brush to apply to the interior pieces.
10-22-2013, 06:13 PM | #3 |
RCC Addict Join Date: Feb 2012 Location: Ca.
Won't the PS colors be dull if used on the outside of lexan. I'm not an expert, but I would think the TS would be the choice for an exterior, like in a hard body?
10-22-2013, 06:31 PM | #4 |
TS would flake off. It won't be dull just more matte finish.
10-23-2013, 12:36 AM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
I have recently painted my Dingo body on the outside. I painted copper (rust), then silver (metal), then red (body color), to simulate rust when the body gets scratched. And yes the paint is dull. But on the plus side, there is nothing stopping you spraying a gloss clear coat (doesn't have to be lexan safe), over the dull paint. That's what I did, and the decals adhered to the gloss surface much better. Best of all is, after a couple of scratches, it is starting to look great.... So in short, if you spray a basic PS color on the outside of the shell first, you can spray TS paints or even normal rattle cans (I use Plascon cans) afterwards with great results. Or, if you worried, use PS paints, with clear coat afterwards... |
10-25-2013, 09:58 AM | #6 | |
| Re: Painting the outside of my lexan body. Quote:
Honestly, I am a bit surprised that TS paint will adhere and NOT crack when sprayed over PS stuff.... I did notice that there is a PS clear also....wondering how that would work on the outside, over a coat of PS. Thoughts? Thanks! Greg | |
12-21-2013, 08:29 PM | #7 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
I did my bronco on the outside with a mix of rust and silver inside you'd be surprised the beating it takes to scratch through the paint but when it does it looks bad azz |
Painting the outside of my lexan body. - Similar Threads | ||||
Painting outside of lexan body | Onebdgti | Paint and Body | 2 | 12-28-2011 10:36 AM |
Painting lexan body outside | davosfam | Paint and Body | 9 | 03-06-2010 06:31 AM |
Painting the outside of a lexan body | canadianbacon | Paint and Body | 5 | 02-06-2010 09:57 AM |
Lexan Body painting for Scaler | dirttrackdemon93 | Paint and Body | 0 | 12-20-2009 08:32 PM |
