01-24-2014, 09:52 PM | #1 |
Quarry Creeper Join Date: Jun 2011 Location: Walnut Grove
| will lexan paint stick to regular plastic and stuff
will it? if i build a cab back out of plastic or aluminum can i paint it with lexan paint or will i need a special primer.
01-25-2014, 04:46 AM | #2 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
All lexan paint is lacquer based unless you get some of the water based stuff. Scuff your shell and shoot it then you'll have to clear it unless you want a semi flat look. For aluminum you will have to prime it with normal auto body primer.
02-03-2014, 08:24 AM | #4 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: will lexan paint stick to regular plastic and stuff
Lexan paint works well and sticks to plastic really well, just make sure you clean it first. As mentioned above, it leaves a satin finish though. If your gonna paint aluminum, the auto body primer will work ok, but there are aluminum specific primers which will work better, such as a zinc chromate primer.
02-04-2014, 07:26 PM | #5 |
Pebble Pounder Join Date: Jan 2014 Location: Knoxville
I've painted the wheels and plastic beadlock rings and the cage of my twin hammers. All of these parts have seen lots of abuse and yet the lexan paint holds up just fine.
will lexan paint stick to regular plastic and stuff - Similar Threads | ||||
Securing LEDs to lexan/plastic buckets | GRandturk | Electronics | 12 | 08-09-2013 11:36 PM |
Lexan Shell Paint Disaster, Paint Removal? | Big Tex | Paint and Body | 15 | 02-08-2012 12:58 AM |
Using Regular Auto Touch up Paint | Gavinlt | Paint and Body | 16 | 05-18-2011 02:04 PM |
will JB weld stick to plastic? | all hung up | Newbie General | 3 | 02-05-2009 07:26 PM |
Best paint for plastic!!! | 90DEGREES | General Crawlers | 4 | 11-22-2005 08:08 AM |
