05-06-2014, 04:25 AM | #1 |
Rock Stacker Join Date: Mar 2011 Location: coos bay, Oregon
| Just wanting to get my ducks in a row.
So I picked a Mojave body kit in white and I'm at the stage in my build where its time to start doing some bodywork. I've never done any work with styrene type hard bodies so I did some searching and read through a bunch of threads and I think im ready but just wanted to make sure I have everything in order, haha. First off, is tenax 7r or plastuc bondene going to be the best route for gluing everything together, or should I be using ca or superglue? Secondly, what's the best filler? I've read Bondo works fine, but I've seen some stuff made by Tamiya.. Is it any better? And finally, how fine of a grit should I take it too to come out half way decent? Any comments would really help me out... Im a total numb at all this bodywork |
05-06-2014, 07:24 AM | #2 |
Rock Stacker Join Date: Sep 2006 Location: PHX Metro
| Re: Just wanting to get my ducks in a row.
I would use tenax or some other plastic welding cement for fixing styrene to the ABS body. CA will work, but it's not a welded fix. For body filler, pick up some squadron putty... it comes in green or white. I prefer the green cause I can visually identify it better. I work with 150, 250, and 400 grit sandpaper while working on plastic/styrene. That's just for bodywork and putty type of stuff. Once the primer goes on I may use those same grits for any defects still visible. For wet-sanding the paint layers (assuming you want a smooth, glossy finish) then use 1200 - 2000 grit. |
05-06-2014, 01:02 PM | #3 | |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Re: Just wanting to get my ducks in a row. Quote:
☆ The Chop Shop What Glue to Use For Body Work/Repairing Cracks in Plastic and Why ☆ | |
05-06-2014, 09:14 PM | #4 | ||
05-07-2014, 06:59 AM | #5 |
No, you want to hold the pieces together and then apply it. You use the brush and apply a couple of fairly heavy coats to the seam. As for the sanding part, you don't wet sand until after you've got your first two coats of primer down. Then you'll wet sand in between each coat.
05-07-2014, 03:25 PM | #6 | |
Just wanting to get my ducks in a row. - Similar Threads | ||||
Ducks 1st day at work. | ROCKEDUP RICKY | Scale Videos! | 3 | 03-23-2014 09:25 PM |
ducks | vito | Chit Chat | 2 | 09-15-2012 06:57 PM |
lol: buddys Go Pro+RC boat+ducks= | STANG KILLA SS | Chit Chat | 32 | 01-28-2011 08:21 AM |
pit row r/c | MaXX_CrAWlER7 | Chit Chat | 1 | 08-25-2007 07:35 PM |
ruh row | 85burbanator | Chit Chat | 7 | 07-05-2006 10:15 PM |
