05-12-2014, 01:02 PM | #1 |
Newbie Join Date: Dec 2013 Location: Central FL
| "hocho-izing" a truck body
After some poking around, I found a gray market body vendor that sells Hardbody/Datsun bodies. I'd like to either buy a tube frame for the back, or make one, because the wheelbase is way too small, but I'm not sure how to remove the bed and prepare the back of the cab to accept a tube frame. Would I just leave an inch or two when cutting off the bed, heat it, and bend it over some lexan, or how would this work? |
05-12-2014, 03:09 PM | #2 |
Quarry Creeper Join Date: Sep 2012 Location: Emmaus, Pa
| Re: "hocho-izing" a truck body
Pics would help, your wording is a little confusing
05-12-2014, 03:32 PM | #3 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Use some sewing thread to cut off the pickup bed and then fill in the area with styrene or ABS plastic so that it becomes a complete cab.
05-12-2014, 04:49 PM | #4 |
I can't find their hardbody, but this should give some idea of what I'm trying to do. I assume I can't just glue plastic across the back without sealing to the sides somehow: |
05-12-2014, 05:24 PM | #5 |
You didn't specify whether the body was lexan or an ABS plastic like a Mojave/Hilux/New Bright body. IF it is a hardbody, Shoe Goo or CA glue will help hold the cab back to the rest of the cab. |
05-12-2014, 05:43 PM | #6 |
Sorry, I meant "hardbody" as in the nissan hardbody/datsun model. It's a lexan body.
05-14-2014, 08:36 AM | #7 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
I'm interested in this as well. Got an urge to take a lexan fj40 and make an fj45 out of it. I'm pretty sure some material will be needed to bandage the thing together from the inside. I'd guess lexan and shoe-goo would cover it. Any ideas about a flexible filler for the seam?
05-15-2014, 09:24 AM | #8 |
Quarry Creeper Join Date: May 2012 Location: Portland
I seriously suggest reading this sticky thread at the top of this section. ☆ The Chop Shop What Glue to Use For Body Work/Repairing Cracks in Plastic and Why ☆ |
05-15-2014, 12:48 PM | #9 |
That thread is a great resource. It's focused on hard bodies, but there is enough info on lexan to keep it interesting. I've begun stitching my shell together using strips of lexan and Shoe Goo on the inside. Haven't chosen a seam filler for the outside yet. Need to figure out what will flex enough, or how to make the shell not flex at all. Also working joining lexan at acute angles. Will probably use lexan strips bent at 90 degrees on the inside.
"hocho-izing" a truck body - Similar Threads | ||||
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde | boolean21 | Scale Videos! | 0 | 10-01-2013 09:39 AM |
