08-20-2014, 05:38 PM | #1 |
| DIY Paint Booth
Finally finished with my paint booth. Here is the main 'booth' part of it: The full structure: I needed more storage, so I build the storage shelves and the booth as one unit. The fan I am using: - It is from Granger (1TDR3). Once I got some issues with airflow figured out it is working pretty well. Here is a short video I shot of it. I am just learning Sony Vegas, and I forgot to turn the wide angle off on my GoPro. Plus, it was a bad day for my dyslexia, had to pause what I was saying several times to pry the right words out of my head... https://www.youtube.com/watch?v=d3l1gMRe2hM I have used it a couple of times so far with just rattle cans. It works very well, pulls the paint fumes away really well. Once in a while I get a whiff of paint, but it is brief and I haven't had to stop painting to let the fumes clear. |
08-20-2014, 06:36 PM | #2 |
| Re: DIY Paint Booth
Nice job, what kind of lighting are you using?
08-25-2014, 05:47 PM | #3 |
| Re: DIY Paint Booth
Just a three-set of under the counter lighting (~$20). I wanted to go with LED lighting, but the only thing they had just did not throw off enough light. The set I have actually works pretty well, I have a couple of projects ran through it and have not had an issue with lack of light.
08-26-2014, 10:20 AM | #4 |
| Re: DIY Paint Booth
That looks Great...Scott. Got that exit hose pumping into your neighbors AC? |
08-26-2014, 03:42 PM | #5 |
| Re: DIY Paint Booth |
08-26-2014, 04:21 PM | #6 |
I wanna be Dave Join Date: Aug 2007 Location: *
| Re: DIY Paint Booth
Here's a good way to keep the over-spray dust down: Go to Walmarts and get a 20"x20" box fan, a 20"x20" 3M Filtrete filter, and some duct tape. Do you see where I'm going with this? |
09-02-2014, 08:23 AM | #7 |
Newbie Join Date: Jul 2014 Location: Central Kalifornia
| Re: DIY Paint Booth
Nice setup!
09-03-2014, 10:10 PM | #8 |
Newbie Join Date: Nov 2013 Location: Gold Canyon
| Re: DIY Paint Booth
So the fan is at the bottom creating a down draft?
09-04-2014, 12:23 PM | #9 |
| Re: DIY Paint Booth Yep. There is a void about 3.5" (the size of a 2x4) between the peg board and the bottom of the booth (where the fan mounts). The fan pulls the fumes through the peg board to the fan. It doesn't generate hurricane force winds or anything, but it does a good job at pulling the fumes away. After getting the color down on a RC body, I put down a couple of thick coats of pearl white (brightens up the paint), the a couple of coats of backing black (protects the paint). Both I put on fairly thick, generating a lot of fumage, but I barely got a whiff of paint when I was putting these two paints on. Optimum for painting is an enclosed booth with a HP fan feeding it, exhausting the air out. This makes sure the booth has a positive fresh air supply and you don't have to worry about the fumes igniting (blowing up) when they pass the blower motor (normal arcing across the brushes to the comm). A negitive air system like this requires that you have a good vent to fresh air, and an enclosed exhaust moving the fumed air away from the supply. For negitive air system you want a ducted fan that has the motor on the outside of the ducting, like the fan I am using. Last edited by Greatscott; 09-04-2014 at 12:28 PM. |
09-04-2014, 09:44 PM | #10 |
| Re: DIY Paint Booth
That's a good idea. I have always vented out the rear and never thought about down the bottom.
09-04-2014, 09:56 PM | #11 |
DIY Paint Booth - Similar Threads | ||||
Upscale Paint Booth | jeepfreek | Paint and Body | 34 | 09-20-2011 02:29 PM |
indoor paint booth help | kuatto | Paint and Body | 14 | 01-23-2011 12:29 AM |
Redneck paint booth | scorpion26 | Paint and Body | 11 | 11-20-2007 11:05 PM |
Need plans for a paint booth | BoilermakerFan | Chit Chat | 17 | 11-23-2006 10:05 PM |
