08-31-2014, 08:31 AM | #1 |
Newbie Join Date: May 2014 Location: n/a
| How can I keep a metal roof rack from damaging body?
I'm planning a new body build, and really want to re-use my roof rack (one of these. Problem is, the last body didn't last very long before the metal posts punched through the body following a few rough spills. I'm wondering if there's anything I could do (maybe nylon washers or o-rings?) to keep the mounting areas from damaging the lexan when landing roof-side down. |
08-31-2014, 08:37 AM | #2 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
| Re: How can I keep a metal roof rack from damaging body?
You may want to post this in the paint and body thread instead of the electronics thread.
08-31-2014, 08:39 AM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Why don't you cut up some pieces of .080 styrene and shoe goo them in place where you're going to mount the roof rack. Then use flat washers on both the inside and outside of the cab on the screws. Other than that, you would have to make some sort of inner structure from styrene or a cage from tubing to keep the can from crushing in during rollovers.
08-31-2014, 08:56 AM | #4 | ||
| Re: How can I keep a metal roof rack from damaging body? Quote:
08-31-2014, 02:54 PM | #5 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
You could possibly even just use body saver mounts, it's lexan cut to go around a body post but it helps to disperse the pressure to a larger area than just where the bolt and nut sit. Add a nylon washer to help even more, the more surface area that's being touched/used around the mount the more it has to push through to damage. -Dan |
How can I keep a metal roof rack from damaging body? - Similar Threads | ||||
3racing metal roof rack | tundrafan01 | Scale Accessories | 0 | 03-15-2011 02:06 PM |
Dingo body+roof rack.. How? | Axialfreak98 | General Scale Talk | 0 | 01-16-2011 10:02 PM |
