10-23-2014, 09:26 AM | #1 |
Quarry Creeper Join Date: Sep 2014 Location: pacific northwest
| Attaching Rear Panel on Hilux
I just ordered a hilux body with the reign rear window panel. What should I be using to attach the back panel to the front cab? thanks for the help |
10-23-2014, 10:25 AM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Attaching Rear Panel on Hilux
What body brand is it? RC4WD or Tamiya?
10-23-2014, 10:26 AM | #3 |
The Tamiya Hi Lift Toyota Hilux
10-23-2014, 10:46 AM | #4 |
| Re: Attaching Rear Panel on Hilux Put some Pro-Weld (Styrene "glue") where the two pieces meet up. You'll start to see the body and rear window frame start to get soft and pliable. Squeeze it together until you see some styrene ooze ooze out. Let it dry and cure for an hour or so. There you have it! If you want to make it a little stronger, put a light bead of Shoe Goo or Goop adhesive in the inner corners of the two pieces when they're together. |
10-23-2014, 10:47 AM | #5 | |
| Re: Attaching Rear Panel on Hilux Quote:
10-23-2014, 10:52 AM | #6 | |
I'm not too sure what the Reign RC window frame is made out of, it may be styrene, I've just never needed to buy one. The styrene weld liquid works great with Tamiya bodies- It just sucks on the colored RC4WD bodies. That's why I asked. When working with plastics, take your time and be patient. It's very relaxing when you get the hang of it. As for painting, I wash it with warm water and dishwashing soap to get the mold release off of the body and then lightly, lightly, lightly scuff it with a fine sandpaper grit. Last edited by Lentsnh2012; 10-23-2014 at 10:54 AM. | |
10-23-2014, 04:56 PM | #7 |
thanks, appreciate the help
Attaching Rear Panel on Hilux - Similar Threads | ||||
Coming Soon Twin Hammer Rear Panel | Barndog Racing | Vaterra Twin Hammers | 2 | 06-07-2013 12:18 AM |
Attaching a Hilux Body to Trail Finder Chassis | Crimson Rock Crawler | Paint and Body | 2 | 11-25-2012 12:33 PM |
Rear LED mounted in panel? | ik632 | Axial Wraith | 4 | 08-29-2012 05:54 PM |
