10-24-2014, 05:40 PM | #1 |
Quarry Creeper Join Date: Oct 2004 Location: Beckley
| Question about body reinforcement
I am wanting to cut the hood on an HPI S15 Silvia body and install an engine bay on my drift chassis and was wondering what I needed to do to reinforce the body once it is cut to help keep its shape. I know that lexan bodies can get a little flexy once they are cut (such as opening the doors or hood) and was wondering what to do to help prevent that? Also what would be a simple way to hinge the hood? I would like to hinge it forward and use something strong enough to hold the hood open for display. Any tips or tricks would be greatly appreciated!
10-25-2014, 08:15 AM | #2 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
| Re: Question about body reinforcement
Fiberglass would be best. On the fenders and front bumper on the inside. You could also use shoo goo and drywall mesh.
10-25-2014, 10:32 AM | #3 |
I have some drywall mesh around here somewhere so I'll give that a try. I never thought about fiberglass but wouldn't the heat produced by the resin potentially warp the lexan? I used to own a custom auto shop and I remember the resin/hardener mixture we used to make speaker enclosures put off some heat.
10-26-2014, 06:27 PM | #4 |
Also guys what are you using for hinges? Im sure there is a simple solution to make some low profile hinges.
10-27-2014, 10:09 AM | #5 |
Newbie Join Date: Sep 2014 Location: Alabama
you could use any kind of epoxy with a mesh or preferably fiberglass mat. Jb weld will even flow into a lot of mesh if you warm it up 1st. I would use jb, 5 min epoxy or maybe even hot glue to attach hinges of your choice. Your LHS should have a bunch of hinges used for airplane elevators/ailerons/rudder, or even a craft store.
10-27-2014, 12:13 PM | #6 |
I never thought about checking the plane section, thanks for the heads up. Im going to use shoe goo and drywall tape so that things stay flexible.
10-27-2014, 05:33 PM | #7 |
Pebble Pounder Join Date: Jun 2007 Location: My House
Most hinges used for standard control surfaces on a plane wouldn't work very well for something like a hood hinge. They just bend in the middle and wouldn't move the hood away from the body like most car hoods move. Robart makes a landing gear door hinge that works a little closer to what a hood hinge would do. They are a little bit larger and they might be less commonly stocked compared to other hinges, but they would look more realistic. |
10-27-2014, 08:11 PM | #8 |
RCC Addict Join Date: Jun 2008 Location: In the woods
| Re: Question about body reinforcement |
11-03-2014, 03:42 PM | #9 | |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Re: Question about body reinforcement Quote: | |
11-11-2014, 06:54 PM | #10 | |
Question about body reinforcement - Similar Threads | ||||
Body reinforcement | Phoenix76 | Rally | 5 | 08-28-2013 10:20 PM |
Rear Battery area reinforcement | SamuraiTrapper | Axial Wraith | 3 | 03-06-2012 12:58 PM |
chassis reinforcement | samguan | General Crawlers | 6 | 06-05-2010 08:59 PM |
wheel narrowing reinforcement. | muddeprived | Tires and Wheels | 12 | 06-19-2007 02:44 PM |
rear link reinforcement | SlammedMini469 | General Crawlers | 1 | 01-07-2006 03:37 AM |
