11-09-2014, 08:31 AM | #1 |
Newbie Join Date: Nov 2014 Location: rochester
| jeeo jk 2dr naked?
I am looking for a jeep jk 2-dr kit (with no top or soft top? a soft top would be amazing maybe if I get real ambitious i could make this myself. I have a 1:1 that is a white jk. I have only seen the proline kits with the hardtop, is there a good option that has no top? I don't have hardtop. this being said, i have the scx10 Deadbolt and i just got it but i threw some 2.2s under it with weight up front. Not sure they will fit with wrangler jk fenders or not. thanks! (noob that is trying to learn the ways of the lil guy- I crawl my jeep and started breaking stuff that was too expensive to justify lol- jeep currently in shop with a 2200$ bent axle ugh) Thanks in advance ! |
11-09-2014, 10:02 AM | #2 |
Pebble Pounder Join Date: Jun 2007 Location: My House
| Re: jeeo jk 2dr naked? 1 10 RC Crawler Truck Body w O Roof Red for Axial SCX10 D90 Land Rover RC4WD | eBay Highly unlikely that any 2.2s will fit in there without looking 10 flavors of goofy. The one I'm working on has the 1.9 Swamper non-XL and they look just about right. Stock Deadbolt wheels and tires would most likely look good and work fine under there. Last edited by S1NN3R; 11-09-2014 at 10:06 AM. |
11-09-2014, 11:07 AM | #3 | |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: jeeo jk 2dr naked? Quote:
If you plan to pay $2200 for a new axle, you're out of your mind. Go to your local CL page or salvage yard and you'll probably find one for an 1/8th of that cost. People practically give away D30/D35 axles. | |
11-09-2014, 11:42 AM | #4 | |
sweet- yeah i still have the 1.9s so could throw back on there. thanks! edit: Rubi axles(dana 44) under non rubi... I have a stock D44 sitting in my garage right now. The issue is they are 32 spline upgraded shafts, 1k electronic locker, custom gearing, trussed, etc. I also went through insurance so in reality it is costing me 500$. I am having the shop weld on new 1/4" upper control arm mounts, upper control arm, and replacing rotor, caliper, piston, mounts(broke in half), new upper control arm, and labor to put it all in. i managed to grenade my brakes, bend control arm and mount on axle housing. I could swap the stock axle under there but would have to source some new gearing, and i don't have the ability to install gears etc- most shops around here won't do it. also, the parts alone for the brakes are around 700 bucks. if i were to buy a new axle, i would go prorock 60 or something of the like, but they are around 4-5k setup i believe. I am still considering picking up a used set of aftermarket axles )i.e. a set for sale for 1800 about 9 hours from me)..but then i would still need all new brake components etc. I could probably handle an axle swap by myself but thats a ton of work with no air tools. if i did that, i would sell the old axles and could get around 2k for them but it is hard with most guys that crawl in california and west coast, up here the demand is a bit lower Last edited by cormac827; 11-09-2014 at 11:45 AM. | |
11-09-2014, 12:15 PM | #5 |
Pebble Pounder Join Date: Mar 2013 Location: near rochester ny
Where in rochester you located ? I'm in Macedon and wanna crawl!
11-09-2014, 04:31 PM | #6 |
| Re: jeeo jk 2dr naked? |
11-15-2014, 07:28 PM | #7 |
Newbie Join Date: Nov 2013 Location: Colorado Springs
One of my buddies just picked up one of those ebay hard body its very scale inside and out
jeeo jk 2dr naked? - Similar Threads | ||||
Naked FXR's | ynmech | Electronics | 21 | 12-05-2012 03:49 PM |
Get naked xr10 | longviewskyline | Videos! | 13 | 02-08-2011 03:53 PM |
Naked PIMP 2.2 | RotaryRush | Tamiya Clod Buster | 9 | 08-08-2008 06:28 PM |
