04-02-2015, 06:56 PM | #1 |
Newbie Join Date: Apr 2014 Location: moncton new brunswick
| Noobie ?
what primer would one use on a plastic body? going to be using parma paints for colour thanks |
01-11-2016, 07:30 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Noobie ?
Lexan or hardbody? Sent from my SM-T350 using Tapatalk Last edited by snapon boy; 01-13-2016 at 08:27 PM. |
01-12-2016, 04:38 AM | #3 |
Rock Crawler Join Date: Sep 2009 Location: Bloomsburg, pa
| Re: Noobie ?
for lexan you dont use primer, you wash the inside well and make sure its dry. Apply window masks and any graphic masking, mix paint and do your thing EDIT: just looked through your threads and see you have a tf2. Sand the body with some light sandpaper and spray with sandable primer ( i like plastikote), let it dry and sand out any issues then start painting after you clean up the dust. Last edited by onebullet; 01-12-2016 at 04:41 AM. |
01-12-2016, 01:45 PM | #4 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Re: Noobie ?
Use a primer that will go with your top coat. In other words if you want a brighter color use a flat white primer as a base coat, if you have or like darker colors you would want to use grey or a dark red primer. Either way I prefer the 2 in 1 Primer from Walmart. It runs around $3 a can, dries very quickly and is compatible with Testors, Tamiya and Model Masters paint.
01-12-2016, 01:48 PM | #5 |
| Re: Noobie ?
Is the ? in place of the word question?
01-12-2016, 10:03 PM | #6 | |
| Re: Noobie ? Quote:
color choice was a big thing to leave out, my bad | |
Noobie ? - Similar Threads | ||||
Noobie help please | 84xcab | Tools, and Procedures | 4 | 03-20-2010 12:07 PM |
noobie ? | freewheelinbronco | Newbie General | 2 | 03-14-2010 06:21 PM |
noobie ?'s | cavie98 | Newbie General | 2 | 12-12-2008 09:00 PM |
noobie ?'s | cavie98 | Newbie General | 0 | 12-12-2008 12:35 PM |
Noobie :D | AFJ | Tamiya Txt-1 and Juggernaut | 5 | 04-28-2004 04:30 AM |
