04-15-2015, 10:38 AM | #1 |
Rock Crawler Join Date: Feb 2011 Location: Williston
| issues airbrushing createx/ fascolor
Its been a while since I have airbrushed much, but wanted to give it a go again on a "junker" rally body. I cannot for the life of me get my Paasche VL to spray this paint. it sputters and spits and coughs then sprays nothing. yes, its clean (ridiculously clean) I finnaly thinned the paint 50% with water and it was better, but not what I remember it should have been. and I know everything says you should be able to spray it straight out of the bottle, but you had better have a freaking HUGE tip to make that work. L.R. |
04-15-2015, 11:35 AM | #2 |
Pebble Pounder Join Date: Apr 2015 Location: canada
| Re: issues airbrushing createx/ fascolor
try different pressures from air supply. some "old" paints need more than a 50% mix due to how they age. |
04-15-2015, 01:57 PM | #3 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
Last attempt at using that paint resulted in me cranking my compressor WAY up to get it to spray right.
04-15-2015, 07:59 PM | #4 |
I went to the largest tip and that helped. still not satisfied though! L.R. |
04-15-2015, 08:52 PM | #5 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Not that it would make a difference for your problem but I always use windex to thin my water base paints. It seems to spray alot cleaner.
04-15-2015, 09:09 PM | #6 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
I paint my share of bodies and refuse to use that paint as much as possible.. but when I have to, I thin it down with windex or alcohol.. and turn the pressure up to 60psi... oh and a big tip.... I have a crappy Badger 150 that I use it with.... good luck........... Last edited by roksloski; 04-16-2015 at 07:41 AM. |
issues airbrushing createx/ fascolor - Similar Threads | ||||
Createx Paint | Phylodog | Paint and Body | 14 | 03-29-2010 01:16 PM |
Useing Createx paint? | jwalker | Paint and Body | 13 | 02-05-2010 01:30 AM |
Createx/Lexan | WVB | Paint and Body | 5 | 02-28-2009 01:15 PM |
createx/faskolor paints | dezu | Paint and Body | 0 | 09-09-2008 07:55 PM |
Createx Paints | Racefan1115 | Paint and Body | 11 | 04-15-2007 08:05 PM |
