04-21-2015, 06:39 PM | #1 |
Newbie Join Date: Mar 2015 Location: Hattiesburg
| Createx paint and ruining bodies - Tips on how now to do what I just did????
A friend of mine and I just attempted to spray my C10 shell and completely destroyed it. We used a detail fun, 35psi, thinned slightly with water, and sprayed LIGHT coats. Prior to taping I wiped the shell down with alcohol. After taping, before spraying, we used a wax and grease remover. I have no idea how we could have prepped any better. Paint didn't stick, it just slid off the sides and pooled up at the body lines. I'm going to use this shell as a test she'll I guess, I don't know. I just wasted 50 bucks though.
04-21-2015, 06:58 PM | #2 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Createx paint and ruining bodies - Tips on how now to do what I just did???? Quote:
Ernie, | |
04-21-2015, 07:15 PM | #3 | |
04-21-2015, 08:43 PM | #4 | |
Ernie Last edited by CODYBOY; 04-21-2015 at 08:45 PM. | |
04-21-2015, 08:55 PM | #5 | |
We used Createx Wicked paints. | |
04-23-2015, 08:44 AM | #6 |
Are you using a scotch brite red pad to scuff up your body?
04-23-2015, 01:34 PM | #7 |
Newbie Join Date: Feb 2008 Location: metropolis
I've painted tons of bodies with createx. There was definitely a little learning curve coming from solvent/laquer type. I think you may have too much gun. If you were using an auto detail gun instead of an airbrush it probably wasn't atomizing enough to get a very fine mist. Key is to get a very fine mist covering the body, take a hair dryer and dry that coat, then go to the next. Once you get a good uniform layer covering the body you can start moving to heavier coat. The hair dryer will def speed up time. I use rubbing alcohol as thinner instead of windex to speed things up. Once painted I back with krylon fusion to make waterproof and scratch resistant. Once you get the hang of it, it works great. I no longer scuff bodies, just wash with soap/water. Stuff it very flexible when dry.
04-29-2015, 06:10 PM | #8 |
Quarry Creeper Join Date: Apr 2014 Location: USA
I would use the actual createx reducer not water. I use a AB with varied tip sizes and have had no issues with adhesion using Createx or Wicked colors. I use a little dish soap and rinse, that's all. No scuffing required, at least I haven't need to. I recently flipped a truck and the roof caved in. I "popped' it back out and it didn't affect the paint at all. No chipping, pealing, or anything. |
04-30-2015, 11:22 AM | #9 |
Quarry Creeper Join Date: Jun 2014 Location: San Mateo
I also apply a couple light coats of clear after adding masks and lightly scuffing, I find the clear coat makes for super sharp paint lines since it actually helps to seal off the masking in areas that sometimes bleed through the paint edges, if the clear gets under your masking you wont see it and the color coat cant since the clear has sealed off those areas.
05-01-2015, 05:49 AM | #10 |
Quarry Creeper Join Date: Jun 2004 Location: Melbourne Australia
Why would you use wax & grease remover , I would hazard a guess that is ya problem mate Warm soapy water Scuff Rinse Mask Paint Kick back and admire ya work It is NOT a car |
Createx paint and ruining bodies - Tips on how now to do what I just did???? - Similar Threads | ||||
JWalker's Tips on Painting Slick Hard Bodies!! | alexchen86 | Paint and Body | 0 | 07-25-2012 12:08 PM |
This is just the kind of Canadian Filth that is ruining our children! | johnnyh66 | Chit Chat | 8 | 07-12-2012 04:21 PM |
Createx Paint | Phylodog | Paint and Body | 14 | 03-29-2010 01:16 PM |
Useing Createx paint? | jwalker | Paint and Body | 13 | 02-05-2010 01:30 AM |
Taking multiple RC+lexan bodies over seas.Any tips? | TheHeadHunter | General Crawlers | 4 | 11-21-2009 02:07 PM |
