09-08-2015, 09:56 PM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
| Scale radio antenna
The nozzle from a bic lighter and a paperclip or similar size wire inserted into an appropriately sized hole drilled in the body with a drop of superglue on the tip makes an excellent antenna Little bent now but you get the idea Last edited by scalemadness; 09-08-2015 at 10:01 PM. |
09-09-2015, 03:40 AM | #2 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
| Re: Scale radio antenna
Excellent idea.....gonna use it! Thanks
09-09-2015, 04:14 PM | #3 |
The body of an empty lighter can also be made into a muffler depending on the size of your rig and the long small spring from the same lighter makes a good mount for a sprung cb antenna
09-09-2015, 04:33 PM | #4 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
LOL, antennas don't work right unless they're bent. Great idea! X2 on using it.
11-10-2015, 10:06 PM | #5 |
Newbie Join Date: Oct 2015 Location: New Brunswick
Not going to lie, when I first seen the image I thought you had cut a resistor in half and glued it to the hood. This works too, be more sturdy than a resistor.
11-11-2015, 11:39 AM | #6 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Guitar string.......... hard to bend...... springs back
Scale radio antenna - Similar Threads | ||||
Futuba radio antenna problem? | cyborgx | Electronics | 1 | 09-23-2014 01:45 AM |
Reattaching radio antenna | LostCrawler | Electronics | 1 | 09-12-2011 01:05 PM |
replacement Radio antenna for spectrum radio | jdacus | Electronics | 10 | 10-26-2010 05:48 AM |
I Screwed Up My Radio Antenna | TIMZKRAWLER | Electronics | 3 | 04-05-2008 01:38 AM |
Mountaineer radio/rx antenna question | rckjeep | Electronics | 3 | 05-11-2006 02:28 PM |
