09-15-2015, 09:24 PM | #1 |
Rock Stacker Join Date: Jun 2015 Location: Ontario
| How to make hardbodys Stronger? |
09-15-2015, 09:53 PM | #2 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
| Re: How to make hardbodys Stronger?
I have never tried brazing a cage, but I once bent up a endocage out of steel rod for the inside of the cab and used shoe goo to attach it to the inside of the body. The pillars between the side windows and the windshield is a common place to break, so I ran a length of rod behind each window pillar. I also made supports out of aluminum to keep the lower sides between the wheels from breaking as easily. Cheap and easy.
09-15-2015, 10:07 PM | #3 |
would you happen to have any picture I get what your talking about. So, bend up some rod of a roll-cage just for the inside
09-15-2015, 10:48 PM | #4 |
I don't have the rig anymore and no pictures unfortunately. I basically just used a tubing bender to bend the solid rod as close to the contours of the inside of the cab as I could get. I tried to make as much of it as possible in one piece bent where needed to keep it stronger. From there, just used shoe goo to hold it to the body. Another option would be to reinforce weak points with styrene plastic on the inside of the body. The window pillars is probably the weakest point on most hard bodies. |
09-15-2015, 11:26 PM | #5 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
If I remember correctly that body is quite thin like a lexan one. Point of that one is to be light....... best way to keep from breaking it is don't flip it. Lol |
09-16-2015, 07:51 AM | #6 |
I you see the way I drive lol , it has a Homles Trailmaster BL in it and I'm going to 3s lipos soon |
09-16-2015, 10:14 AM | #7 |
Quarry Creeper Join Date: Oct 2014 Location: East
Here is how I caged mine... This setup survived the ECSC with plenty of hard roll overs. The truck is heavy but the cage helped save the body. Last edited by drzoo2; 09-16-2015 at 10:19 AM. |
09-16-2015, 11:33 AM | #8 |
Thanks, I'll have to give it a try
09-16-2015, 12:54 PM | #9 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
I have epoxied piano wire in the A-pillars and across to front of the roof before. That's all I've had break on my hard bodies so far..
09-16-2015, 02:17 PM | #10 |
What kind of epoxy did you use and would metal work the same of even wood work
How to make hardbodys Stronger? - Similar Threads | ||||
The "break-it-to-make-it" stronger wraith | Jfrisch01 | Axial Wraith | 2 | 11-23-2014 07:59 PM |
Different Hardbodys | BansheeManiac | Paint and Body | 7 | 09-02-2010 01:05 PM |
How to make your MRC Wider and stronger for Cheap. | redrover | Losi Mini-Rock Crawler | 22 | 10-23-2009 08:37 PM |
how can i make my tranny stronger.. | mudhunter | Newbie General | 0 | 12-13-2006 11:49 PM |
how to make VMG R&P stronger? | youngblood | General Crawlers | 2 | 09-08-2006 09:30 PM |
