Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Filling Hard body plastic holes.
Old 11-20-2015, 04:26 PM   #1
Default Filling Hard body plastic holes.
What are you all using to fill in holes in hard plastic bodies and like smooth out body lines? I stared a scale build need to fill on some holes.
If you can Post pictures of the items that will work.
Thanks for your time!
espnstang25 is offline   Reply With Quote
Old 11-20-2015, 07:11 PM   #2
Default Re: Filling Hard body plastic holes.
I used small bits of styrene in mine. Just the leftover tiny pieces. Put them in the hole and put a good bit of the solvent on them a few times and it softened it up enough to get pretty solid. Once I was happy with that I used body filler putty and smoothed them over and sanded.
struhall is offline   Reply With Quote
Old 11-21-2015, 07:35 AM   #3
I agree with struhall. I will back the hole with a small square piece of styrene, then fill it with small bits, or recently I used round solid styrene rod just slightly smaller then the hole. That worked extremely well as it required less filler. Less filler = less chance for any cracking / shrinking of the repaired area. IMO!
joe122 is offline   Reply With Quote
Old 11-21-2015, 07:42 AM   #4
Fan of wheelspeed
Here's how I fill holes. Drill out the holes to the size of your round styrene stock (easily found online or at nearly any hobby store). Use CA glue on the round stock and work the styrene into the newly cleaned out/drilled hole. Once the CA glue has cured you can cut the styrene off even with the surface of the body.
Once that's done you can sand down the surface until it's smooth again. You can then back the hole with another piece of scrap styrene and some CA glue or use a thin layer of ShooGoo. Don't use a thick layer as it will shrink once it has cured and may cause warpage in certain thin plastics used in a few hardbodies floating around.
Hoosierdady is offline   Reply With Quote
Old 11-21-2015, 11:58 AM   #5
That makes a lot of sense. Really great tip. Thanks!
Filling Hard body plastic holes. - Similar Threads
filling holes? jahoban Paint and Body 3 06-06-2009 12:54 AM
Filling Hard body plastic holes GeoffSFAs10 General Scale Talk 7 03-07-2009 03:24 PM
Filling holes in a hard body Rat1 Paint and Body 8 11-23-2008 03:59 PM
filling holes/scratches ben_smits Newbie General 8 04-20-2007 08:19 AM
filling holes in tubing... WRMorrison Tools, and Procedures 14 11-26-2005 12:05 PM
