01-09-2016, 05:32 AM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Grover, NC
| Ok to back with Rustoleum?
Painting my Jeep Rubicon crawler body Candy Yellow and bought silver as a backer but did not like the glitter effect. So on a scrap piece of lexan I sprayed the candy yellow and just sprayed white Rustoleum primer on for a backer to test the color outcome and the outcome is spot on! The exact yellow I was looking for. Question is, do you think the Rustoleum primer will hold up well? The candy yellow is duratrax polycarbonate paint, then the white Rustoleum is just the backer. Think the Rustoleum would hold up, and stick, and not Crack up? If I have to order a can of white duratrax poly paint I will but just seeing if any out there has tried a different kind of spray paint that can be bought at local dept stores or hardware stores. |
01-09-2016, 11:10 AM | #2 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: Ok to back with Rustoleum?
It will crack....... use lexan paints
01-10-2016, 03:02 PM | #3 |
As long as the first color on the lexan is a polycarbonate paint, any paint you put on afterward won't matter, as long as it's compatible. I've used Testor's or Rustoleum flat black as backer paint on mine with no chipping or peeling. I use multiple colors when painting lexan to get a chipped paint/rust effect on both the outside and inside. However, your results may vary, best to test on a piece of lexan that you cut off from the body. |
01-12-2016, 07:07 AM | #4 |
Quarry Creeper Join Date: Feb 2012 Location: Near the IL/WI border
I've had good luck using Krylon Fusion as a backer. It's designed for most plastics so its adhesion and flexibility properties are greater than that of "standard" spray paint. At least in my experience.
01-12-2016, 10:30 AM | #5 |
yep been using walmart .98c flat black for backer for years be sure to let your lexan paint fully cure for 1-2 days before backing so you dont get a reaction. i also mist the first few coats of backer as well to prevent a possible reaction, and help the physical bond of the two paints. Last edited by STANG KILLA SS; 01-19-2016 at 02:32 PM. |
01-19-2016, 08:35 AM | #6 | |
RCC Addict Join Date: Nov 2008 Location: Frederick
| Re: Ok to back with Rustoleum? Quote:
01-19-2016, 01:54 PM | #7 | |
Rock Crawler Join Date: Mar 2010 Location: Onalaska
01-19-2016, 06:22 PM | #8 |
No problem rj, with the masterpieces you've built, I'm more your student, |
01-26-2016, 09:09 PM | #9 |
| Re: Ok to back with Rustoleum? Thank you for complement but there far from masterpieces you build very well to and there is many many people on here that I am umbarist sometimes to even show my builds there are so good lol
Ok to back with Rustoleum? - Similar Threads | ||||
Had a little fun with some Rustoleum paint and my wifes SUV yesterday | Hoosierdady | Chit Chat | 11 | 05-09-2015 07:19 AM |
rustoleum never wet? | Beej | Axial SCX-10 | 2 | 07-30-2013 09:23 PM |
Proper Clear coat for rustoleum acrylic | sbchero | Paint and Body | 4 | 04-12-2013 04:02 PM |
Rustoleum Enamel | Mr.Joshua | Paint and Body | 11 | 10-18-2011 09:44 PM |
Any paint geeks out there?? Rustoleum | picklewagon | Paint and Body | 13 | 02-10-2010 10:08 AM |
