01-31-2016, 05:06 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
| Bed liner?
I just bought a can of Rustolium spray on bed liner with the intentions of doing the roof of my Bronco body. Other than light scuffing of the Lexan, is there anything else I need to know. Figured I'd practice on some old bodies first, but is there any tricks or don't do's I should know about? Any pointers at all are greatly appreciated!
01-31-2016, 05:52 PM | #2 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: Bed liner?
I tried the Rustoleum that is labeled "Bonds to plastic". It does not bond to plastic. Bull Sh*t!
01-31-2016, 06:46 PM | #3 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: Bed liner?
I don't know if it works but there are some utube videos about it.
01-31-2016, 06:52 PM | #4 | |
Pebble Pounder Join Date: Jan 2015 Location: South Central PA
| Re: Bed liner? Quote:
I used the rustoleum 2x paint that says bonds to plastic on 2 hard bodies and it worked great. It does have a long cure time on plastic though. It took about 5 days for it to fully harden up. Lexan is a totally different you really need lexan specific paint. | |
01-31-2016, 11:06 PM | #5 |
Quarry Creeper Join Date: Mar 2014 Location: Rogers, MN
| Re: Bed liner?
Use a can of polycarb paint as a primer, then you can spray almost anything on top of that without chipping away (unless you do a single heavy coat with the polycarb paint) I've done this to quite a few lexan bodies using standard rust oleum and standard krylon spray cans to paint them on the outside. A few light coats of Tamiya PS-5 and then Krylon and/or Rustoleum on top -Derek |
02-01-2016, 06:15 PM | #6 |
| Re: Bed liner?
Thanks guy's! I think I'll take some of your tips and practice on some old bodies and see what's going to work. Thanks again for taking the time to help!
02-02-2016, 08:17 AM | #7 |
Pebble Pounder Join Date: Feb 2009 Location: CALDWELL
| Re: Bed liner?
I myself have used the textured paints from krylon with the above stated prep work and then covered it with black or any color you want the bed liner to look.Just my experience.
03-16-2016, 09:11 PM | #8 |
Rock Stacker Join Date: Nov 2004 Location: middle of nowhere
| Re: Bed liner? |
03-16-2016, 10:33 PM | #9 |
Quarry Creeper Join Date: May 2007 Location: Montucky
| Re: Bed liner?
That looks really good artl666. I sprayed my wraith roof with line-x today.
03-16-2016, 10:48 PM | #10 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| Re: Bed liner?
I've used Duplicolor's bedliner with their adhesion promoter as a primer. My procedure is to clean the lexan, scuff it with sand paper, clean it again, apply the adhesion promoter as recommended on the can, let it set up for 10-15 minutes, then apply the bedliner as recommended on the can, then let the paint cure and unmask if necessary.
03-27-2016, 07:30 PM | #11 |
Newbie Join Date: Mar 2016 Location: Marion
| Re: Bed liner?
artl666 is that the axial wrangler body you used that technique on?
04-04-2016, 05:26 PM | #12 |
| Re: Bed liner?
yeah lucky87 its the rubicon unlimited complete body and top from axial
Bed liner? - Similar Threads | ||||
Grip tape bed liner | Superbeast | Paint and Body | 0 | 08-07-2012 09:23 PM |
Bed liner | cougardave | RC4WD Trail Finder 2 | 2 | 07-25-2012 05:53 PM |
Truck Bed Liner | MICHIGAN CRAWLER | General Crawlers | 2 | 02-02-2012 04:19 PM |
the perfect paint - bed liner!!!! | robmurray12 | General Crawlers | 7 | 09-05-2005 02:12 PM |
