Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: Question on painting a body?
Old 01-08-2007, 02:32 PM   #1
Default Question on painting a body?
I read somewhere that using electrical tape for masking lines on lexan bodies works really well. It's thin and able to stretch to make contoured lines. Has anyone here actually tried using it? It seams like it would work well but I don't want to ruin a body. I've done liquid mask and I just can't seam to cut perfectly straight lines and it ends up looking poorly.
calyakker is offline   Reply With Quote
Old 01-08-2007, 03:50 PM   #2
1*
rcr3fan29's Avatar
I used electrical tape to mask off these stripes on my SW2:
rcr3fan29 is offline   Reply With Quote
Old 01-08-2007, 04:32 PM   #3
I use Blue Painters tape for all my bodies, granted they are not the best but thats due to my painting no the masks I make.
TQ
tq_racing is offline   Reply With Quote
Old 01-08-2007, 10:51 PM   #4
i would thing elect. tape would leave some sort of a reisdue on the body... anything like that?
mrpink is offline   Reply With Quote
Old 01-10-2007, 12:05 AM   #5
I thought the same thing. But I think if you don't leave it on longer than necessary it may be OK. I just wasn't sure how it would react with the paint. Since the paint is supposed to chemically bond to the body, it seams possible to bond to the tape also since it's a pvc based tape. I kept the original tlt body. Maybe I'll try it on that and I'll post the results.
Old 01-31-2007, 01:44 PM   #6
High Plains Drifter...
Big Mike's Avatar
I used electrical tape to mask the last bronco body I painted (I did a two-tone black and coral blue)
It sticks to lexan well so it won't bleed through.
It stretches to conform to curves well.
It leaves a nice sharp break when removed.
It does'nt leave residue unless it's left on for a long time. If you peel it off the next day you should be fine.
I used Tamiya paint last time, and saw no chemical reaction between the paint and the electrical tape at all.
Big Mike is offline   Reply With Quote
Old 01-31-2007, 07:17 PM   #7
I joined the Band!
if you use electrical tape dont try to stretch it to much or it will leave a residue, however if you do get that sicky residue their is this wonderful stuff called "goo gone". it is pure citrus oil and will take off any residue. I use windex to get the "goo gone" off afterward.
rockwar is offline   Reply With Quote
Old 01-31-2007, 07:20 PM   #8
lohocla's Avatar
I use goo gone on a daily basis almost... powerful stuff.
lohocla is offline   Reply With Quote
