04-21-2016, 01:56 PM | #1 |
Rock Stacker Join Date: Oct 2015 Location: Southern Oregon
| Honcho Cage Touch Up
Hello, (If this has been suggested before, please credit the person or thread.) I wanted a cleaner look for my Honcho, so after making a short bed that I wanted, I then cut off the existing tabs on the roll cage that were there for the longer bed. This left a gray area where the cage was filed and sanded. I found that if you use a black permanent marker that it will match the original color fairly close. After applying the permanent marker and letting it dry for approx 10 minutes, lightly go over the streaked surface that the marker leaves with extra fine steel wool. With a little practice you will find out how much effort is required to match the existing color. If you go over the area too much, just re-apply the marker and start over. I hope this helps someone as I found this to be a simple, and cheap, solution to “pretty” up the cage. Now I can go out and scratch it up…... |
04-21-2016, 02:22 PM | #2 |
| Re: Honcho Cage Touch Up
That looks good. The plastic resembles anodized aluminum after the Sharpie.
Honcho Cage Touch Up - Similar Threads | ||||
My touch to the cage mod | nahuebsch82 | Axial Wraith | 2 | 03-16-2015 01:51 PM |
Non-honcho body for honcho roll cage question | Jgreen76 | Axial SCX-10 | 2 | 01-27-2015 11:41 PM |
