05-29-2016, 11:43 PM | #1 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Is this the correct way to do this
I own a set of 1.9'' Hutchinson beadlocks And wanted to paint them So I took a Dremel wheel that is Like a Scotch Bright pad and scuffed up the surface Then cleaned them in dish soap and water and a little ISO Then applied a couple coats of Etching primer and let it fully dry Between coats And used Flat Camouflage Deep Forest Green as the top coat The I used some Flat Testors Dullcote Clear Lacquer Curious if it will scratch off while assembling the beadlocks They look good with black socket cap screws and SLW hubs painted too Last edited by kgb424; 12-11-2018 at 01:35 AM. |
Is this the correct way to do this - Similar Threads | ||||
Is this info correct? | Cainlord | Axial SCX-10 | 6 | 10-08-2014 09:02 AM |
Gearing (is this correct?) | 08sv | Newbie General | 3 | 12-05-2012 05:52 PM |
Which way is correct? | scruff007 | Electronics | 11 | 01-14-2007 12:51 AM |
